Tool Talk Discussion Forum
trailer rim size
gmc ronnie
04-05-2008 02:28:07
the size of the rims are regular trailer rims that they call 5 x 4 1/2 . that"s the rim size on the hub . what car manufactors rim can i use with the same bolt pattern ( 5 x 4 1/2 ) that i can pick up cheap at the junk yard , . thanks
Bus Driver
04-05-2008 16:23:40
 Re: trailer rim size in reply to gmc ronnie, 04-05-2008 02:28:07
Lots of Chrysler products used 5 lugs with 4 1/2" bolt circle for many years. 1/2 ton Dodge, too.
jose bagge
04-06-2008 05:00:28
 Re: trailer rim size in reply to Bus Driver, 04-05-2008 16:23:40
yep...AMC too
gmc ronnie
04-05-2008 07:17:51
i have two new trailer rims on my trailer now , what i want to do is take them off and put the junk yard one's on so i can sell the trailer . i'll look for some small ford truck rims .thanks
jose bagge
04-05-2008 05:51:45
 Re: trailer rim size- ford car in reply to gmc ronnie, 04-05-2008 02:28:07
That's ford passenger car ( well, it was when they weren't 4 bolt). Most current would be small ford 2wd truck.(bronco II, etc)
you can buy a new white spoke in a 14 or 15" for about $20 in this bolt pattern, so don't pay to much for a junk yard wheel
Ford Small car= 5 on 4.5
Chevy small car= 5 on 4.75
Ford/Chevy Big car (old lincoln/ Caprice) + 2wd chev pu = 5 on 5"
Ford Big PU : 5 on 5.5
Most 6 lug = 6 on 5.5
renault leCar= 3 on 130
fiat x1/9 4x110mm
MGB 4 on 4.5
vega 4 on 4 (also austin healy sprite
Man, i remember way too much useless junk from selling custom wheels 20 years ago
Jeff in TX
04-05-2008 12:26:33
 Re: trailer rim size- ford car in reply to jose bagge, 04-05-2008 05:51:45
Tell me where you can buy new for $20. I need a few.
jose bagge
04-05-2008 18:52:29
 Re: trailer rim size- ford car in reply to Jeff in TX, 04-05-2008 12:26:33
In Texas, try NTB. don't let them order American Racing (too expensive), you want Mangels or KMC
jose bagge
04-05-2008 06:56:10
OOPS-
fiat x 1/9 4 on 98mm
mazda rx7 4 on 110mm
everything else jap car 4 on 100mm
walts saab sonnet 5 on 130 (?)
someone on here had an alfa romeo 4 on 4.25, same as ford car....
late vw bug 4 on 130, early vw bug 4 on 130
early subaru (brat) 4 on 140
brain flood....
T_Bone
04-05-2008 05:36:18
Hi ronnie,
Also besure your trailer does not use hub concentric wheels, meaning the center of the wheel fits snuggley over the hub face and carrys part of the wheel load weight. This should not effect axles under 5k rating but you never know.
I just paid $75 delivered for a new pair of 5x41/2, 13" modular rims for my boat trailer. southwestwheel.com
T_Bone
Lester Elwood
04-05-2008 05:00:42
Hi Ronnie I needed a rim for my equipment trailer. I went to the junk yard here an got a Ford Ranger rim, goes right on no problems. Hope this helps you. Lester
