Tool Talk Discussion Forum
Your favorite trailer configuration?
s.crum
04-04-2008 05:29:43
I've been passivly looking for a decent USED flat deck trailer about 16 to 18 feet long and 7' or so wide for a couple years. I've pulled several different types. I want to get something reasonably priced as it will spend most of the time as a lawn ornament. But I want to be able to haul a medium sized car or a pick up on it if needed, otherwise I want to be able to haul my Hobart engine drive welder and gang boxes on it.
Deck overs are nice but pretty high off the ground.
I'm going to "di-vest" 3 of my old Deeres that I'm not going to have the time to restore, and several other things that I'm getting tired of looking at and having under foot to be able to pay for this.
I'd like to get an idea as to what is the most popular configuration and what holds it's resale value best.
buickanddeere
04-07-2008 17:55:57
 Re: Your favorite trailer configuration? in reply to s.crum, 04-04-2008 05:29:43
The high center of gravity concerns of deckovers is way over rated.
After having a full 102" wide deck to use, you won't go back to staddling fenders.
Instead of the beavertail ramps, the tilting deck if better, safer and more practical.
I never seen anybody regrette going upsize on the springs, axles & tires weight capacity. Even though they will never use it.
Four wheel brakes rather than 2 wheel too.
mj
04-07-2008 09:28:46
 Re: Your favorite trailer configuration? in reply to Eric SEI, 04-04-2008 05:29:43
This my 24' PJ steel-deck that I'm real happy with. PJ makes single and dual wheel trailers in about any length and either high or low deck. I've got a 16' bumper-pull that I can pull behind the goose for those 'strange' loads like, hay on the PJ and a hot-tub on the bumper-pull :roll: Right here it's set up for helping a buddy on the other side of the hill and still having a place to 'sleep on the cheap'. :)
third party image
You can find PJ here - Link
Aberdale Farm
04-06-2008 19:04:14
I like a gooseneck for backing. But I've got a pickup and a dump truck. Can't use a gooseneck with the dump truck, so I've compromised. I have a 18+4 bumper pull with a pintle hitch. It's a tri-axle (three 7,000 lb axles) deck over with singles (six tires total.) It has a metal grate deck so it won't hold dirt and it won't rot out. (Yeah, it will probably rust away some day, buy I try to keep it painted.) I will add a third ramp to it someday for narrow front tractors.
It pulls straight as an arrow and I can haul 20,000 lbs behind the dump truck with no problems. The best part? It cost me $800 at an auction. At that price I decided I would use it until I found something better. But the more I use it, the better I like it, and I've used it for almost 8 years now.
Dale
Gary from Muleshoe
04-05-2008 12:09:33
Take look at this one in the photo ads.
Gary from Muleshoe
04-05-2008 12:09:08
T_Bone
04-05-2008 05:22:23
Hi s.crum,
Had I bought the right trailer 30yrs ago I sure would have saved a ton of money over the years.
What I found works best, is a 20ft x 8ft deck, 5th wheel with single duals. Why?
The 20ft deck is just the all around best deck size, not too big for town but big enough to haul any decent load of any type.
A single dual axle as it pulls well and extremely stable side x side and 10k axle rating. You still only have 4 tires to replace.
5th wheel as it's just plan easy to use vs a GN or tag. Rasie the pin to the correct height, back-up until the pin latchs, raise the jacks and your done. You only have to be with-in 2" of the king pin for it to lock. Use quick attach bed rails and slide the hicth out with it still attached to the trailer. Clean bed when your done other than the rails. No getting out of the Tv to check to see if your over the ball. The bolster plate design also adds to the trailers side x side stability.
Ramps on the dove tail can be flipped up to make a smooth 20ft deck when it's needed. Get the third ramp!
I-beam frame rails as it's just a stronger design vs channel. 3" channel cross beams on 16" centers.
A 6" torque tube as this keeps the deck frame from twisting when hauling rolling load weight or loading heavy on one side of the trailer first then loading the other side.
LED lights!!! Accept no others.
Trailers are pay me now or pay me latter, but your gonna pay me before your done. So spend the extra $2000 now and have a trailer that will last you a life time. You should be able to buy this trailer in Texas for around $3500 new and $500 to deliver.
T_Bone
jose bagge
04-05-2008 06:04:40
 Re: Your favorite trailer configuration? in reply to T_Bone, 04-05-2008 05:22:23
don't see many "single duals" up here...sounds like just the ticket. Plentiful down your way?
Probably easier on tires due to reduced turning scrub...
T_Bone
04-05-2008 06:36:47
 Re: Your favorite trailer configuration? in reply to jose bagge, 04-05-2008 06:04:40
Hi jose,
Ahh but he was asking what the best trailer design was and to me that's what I described.
Plus the duals add to side to side trailer stablility.
I found that very few used trailers are sold that are not junk, so if your going to buy new, a fellow might as get what he wants as it's not going to cost more.
T_Bone
Bud in WV
04-05-2008 03:39:01
Before moving out of NC last year I picked up a NEW 18' x 7k lb flatbed trailer from TRT Trailer Sales for $1700. The 18' x 5t trailer costs $2200. They also sell some used stuff. Heres a link - might be worth looking at. They have good prices.
http://www.trttrailersales.com/
Jlmtractor
04-04-2008 18:47:15
it is hard to find a deckover gooseneck here in sc. for what you are halling I would say like a twenty or 18 foot deck between the axle trailer with like 5 or 7 thousand pound axles. I would go with 7 so you could hall anything you wanted with no worry of wieght. I use a 24 foot deckover with two 7 thousand pound axles. I use a deckover just to be able to load things easier like attachments and things.
Gary from Muleshoe
04-04-2008 17:39:30
I have a 16' X 82" that I bought new back in 1996. I replaced the floor in it last October and repacked the wheel bearings just this past month. It has spent a lot of time setting also. But now it gets used quite a lot in the summer months to haul my 1940 JD B to shows and parades. With any luck it should last me another 12 years or more. Not to bad for a $800.00 trailer. I have found this size to be very versatile for all my needs. Trailers like it now go for around $2,500.00 new. Try looking on Ebay you can get some good ideas on there.
Bob Huntress
04-04-2008 13:21:02
I have a 20' bed on my flatbed trailer and 8' across. Add about three feet to the pintle eye, and my tandem axle trailer is awesome. I hauled everything that I own from Buffalo, NY with it about four years ago. I found the trailer in a field in Lockport, New York, and a friend of mine from church, and I worked about a week welding it back to road worthy. The bed sits about 3' high, and there are stake rails that go up another four feet. I have another axle to add to it, since the two that are on it are a bit too forward. This will give me a good distribution of weight, as well as allow me to haul bigger loads.
jose bagge
04-04-2008 11:38:42
I have found that my most useful trailer is a 16" tag-along. i can pull it behind pick up or dump and still carry a load in the truck, and i can tote it behind the suburban or motorhome as well. It sure does get borrowed a lot, though..... ..
RobMD
04-04-2008 09:56:51
They DOOOO make a gooseneck trailer that is low and has the fenders - i'm not sure where you would get one as they are kinda rare.
16 foot would be perfect.
Davis SC
04-06-2008 19:30:10
 Re: Your favorite trailer configuration? in reply to RobMD, 04-04-2008 09:56:51
That is what I have, low-deck 16 foot GN, 12K. I had it built by Stoll in Abbeville, SC. It works great for a big skidsteer. I sometimes wish it was a foot or 2 longer, the bush hog hangs over the back a bit when I haul the MF 245.
i
s.crum
04-04-2008 10:07:18
I took a look at a nice used tow behind trailer this morning that is a 7000 lb. I wasn't thrilled that it only has 24" treads for the deck instead of a solid deck. I could easily fill the center and convert it to a gooseneck. But for $1,600 I might keep looking for awhile. I'm thinking that with all the trailers that have been sold in the last few years to the "fancy pick-up and SUV crowds" and that the economy is belly up, there might be some deals out there as in 'the payment is due on my fancy pick-up or SUV'.
Goose
04-04-2008 08:44:42
If you go with a goose-neck, it eliminates 98% of the continuous line of people who want to borrow it.
dhermesc
04-04-2008 14:05:43
 Re: Your favorite trailer configuration? in reply to Goose, 04-04-2008 08:44:42
"If you go with a goose-neck, it eliminates 98% of the continuous line of people who want to borrow it."
Agreed.
Big Hunter
04-04-2008 07:00:27
I have a 18 foot car hauler. 10,000lb. 2 axles, both axles have electric brakes, 2 and 15/16 inch ball hitch. I think I paid $2,200 for it a few years back new. The only thing I did was add some angle iron under the deck across from side rail to side rail because the skid steer I haul weighs around 8,000lbs. and the load is all within about 6 feet. (wheelbase of skid steer). And the frenders sticking up above the deck do get into the way sometimes, but I have managed.
Make sure you compare the spacing and size of the rails and cross members. My cross members are angle iron, I think channel iron would be better.
MSS3020
04-04-2008 06:16:22
I have a car hauler 18 long. Love it .hauls skid loader nice and cars and lawntractors but wont haul my tractor to light. 3500 ax dont cut it Ive looked and my next one will be one of those trailers that has a tilt you can load with out ramps once trailer tilts down your good pin it and go. Also comes with a 4 foot stationary deck at front. Better than that would be the above mentioned with a gooseneck.
Mike M
04-04-2008 05:49:13
Well it all depends on what you plan to haul ? If you are still going to mess with old tractors then a deck over is almost a must have because then you don't have to worry about moving the wheels in. The newer ones with torsion axles sit lower than spring axles. I really like a gooseneck type. Lots and lots of brands and styles being made today than ever before.
tja toolbx
04-04-2008 05:39:54
I really like a car hauler style with a wood floor. I had added stake pockets and rub rails. This allows me put removeable sides. The wood allows me to easily attach stuff to the floor. ie screw job boxes down so they don"t have to untied to open the lid. Also bought a used hitch set with load lever bar, I use when hualing heavier items.
