Tool Talk Discussion Forum
Setting Up Auxilary Air Comp. Tank
Glenn F.
04-03-2008 10:13:58
I am about to add a 100 Lb auxilary tank to my air compressor system. My lead compressor has a 60 gallon tank, and my secondary one has a 35 gallon tank. They are hooked together. Both compressors currently have check valves. I plan on T-ing into the line that connects the two tanks.
On an earlier thread someone suggested I install a check valve when adding the LP tank. Is this necessary?
Thank you,
Glenn F.
Dick L
04-04-2008 09:15:50
 Re: Setting Up Auxilary Air Comp. Tank in reply to Glenn F., 04-03-2008 10:13:58
We had a 100 horse compressor beside a 75 horse compressor that was put in after a bank of four 30 horse compressors that would not handle the plant expansions. All on unloading valves and no check valves. We did enlarge the the overhead lines that were 250 feet long. Air has more friction than water when being forced thru pipes. Larger airlines are more productive than setting extra tanks unless you have a machine that takes a large volume of air instantly.
Glenn F.
04-04-2008 13:27:05
 Re: Setting Up Auxilary Air Comp. Tank in reply to Dick L, 04-04-2008 09:15:50
I spoke wrong in saying both of my compressors have check valves. They have hydraulic unloaders.
Glenn F.
jose bagge
04-03-2008 20:00:28
I have 28 shops all running double compressors, and have NEVER run check valves in an of these installations. From your post, I have assumed that you are adding an additional TANK as opposed to an additional compressor- so again, no check valve necessary. If you are looking for additional air reserve capacity, do not neglect your trunk lines- go large diameter pipe along the walls and it will have the same effect as additional tank storage.
Gun guru
04-03-2008 14:28:05
There is 2 ways to do this, If I understand your comment correctly. 1. Run both systems at the same time and use an electronic sequencer to alternately cycle each compressor through the load/no load duty cycle. This is done in industrial plants. 2. Or are you trying to have 2 compressors hooked into the same system so that you can not wear one out (actually get use of both compressors) If this is the case then use a shutoff valve on the output of each compressor and have the aux tank in between the 2 shutoffs. Be sure to have a drain on that tank, and for the whole system.
Charles (in GA)
04-03-2008 14:23:29
When plumbing two compressors together, it is necessary to have check valves on the tank outlets of each one, going into the air system. The pressure switches are not exactly the same, and may be dramatically different. If you didn't have the check valves, one compressor would be dominant and the other one would probably not run. As soon as the pressure got low enough for one compressor to come on, it would, and begin pumping up, thus the pressure would not get low enough to cause the second compressor to turn on. With check valves, the compressor operates in its own world and doesn't see the pressure in the rest of the system, thus both can supply air and operate if needed. One will still remain dominant, but in instances where the air consumption is high, both would operate. That is my take on that.
As far as a tank without compressor goes, I see no reason to install any kind of check valve.
Charles
Circus
04-03-2008 13:51:00
Don't understand the what a check valve would do. A relief valve is for safty on any pressure vessel.
504-2
04-03-2008 16:35:05
 Re: Setting Up Auxilary Air Comp. Tank in reply to Circus, 04-03-2008 13:51:00
Glen, The only problem I had using a 100# LP tank was the valve in the tank had a restrictor in it, so I took the valve out and drilled it oversize and put the valve back in. ( I use it for an air tank.) that also keeps the built in safty on the tank.
Frank A
04-04-2008 16:56:04
 Re: Setting Up Auxilary Air Comp. Tank in reply to 504-2, 04-03-2008 16:35:05
Pressure relief valves on most DOT cylnders are rated at 375 psig so I wouldn't count on it to help protect your system much.
