Removing j b weld
Matthew T Hardi
09-01-2001 06:33:50
Does anyone out there know how to dissolve j b weld? I used it to put my weed eater back together. Now the j b weld is in the grooves where the two parts come together, and I'm having difficulty having the j b weld hold it on anymore. I need to try to get the j b weld out of the grooves. Any help would be appreciated.
Thanks, Matt
Dean
09-01-2001 10:03:49
 Re: Removing j b weld in reply to Matthew T Harding, 09-01-2001 06:33:50
600F heat from a propane torch will do the trick, IF it is safe to do so. If your "weedeater" is made of plastic, forget this trick!
Otherwise, JB Weld can be worked just like metal.
