Tool Talk Discussion Forum
Water and Electricity
tractormarkb
04-01-2008 09:41:31
While trying to pump out my back porch yesterday I noticed that the Sump Pump Cord where it plugs into the extension cord was under about 4 inches of water. I could still see part of the silver plug ends between the cords yet the sump pump was running just fine. I told my wife it still ran because the water we had wasnt the real wet kind, but serously how could the pump still run and not have a short between the two cords??
Phil Doolittle
04-01-2008 13:34:56
 Re: Water and Electricity in reply to tractormarkb, 04-01-2008 09:41:31
All of the comments given are valid, BUT it is DEADLY to be using any pump or 120 volt electrical device outdoors-indoors near water such as a sink without the CIRCUIT having GROUND FAULT PROTECTION !!!.You are playing Russian Roulette. The NATIONAL ELECTRIC CODE(NEC) defines the requirement & locations for their use. As a professional electrical engineer and a consulting technical expert I have witnessed and have testified to their use and installation in courtroom fatalities. Don"t be another statistic, when they trip its TELLING you something important. For $10.00 it will save your LIF>
dr sportster
04-01-2008 11:11:01
It would trip a gfi.Water is not conductive itself,its what in the water.
tech4
04-01-2008 11:06:50
Everyone is correct that pure water is not a conductor. Many of the old high power radio transmitters used water cooled tubes that had the plate connection with up to 10,000 volts in the water but no problem as long as the water was pure.
I am guessing that your water was not that pure and there was probably some leakage between the connectors but only in the milliamperes not amps and that did not pop a breaker or fuse. Be sure and turn the power off and dry out those connections soon to prevent corrosion and a real problem later.
John T
04-01-2008 10:41:53
Mark, Tap or well water has minerals which make it a conductor, albeit generally a poor high resistance one. Distilled water would be less conductive (higher resistance to current flow) cuz a lot of those minerals are absent. Water is still hazardous around electricity cuz even if its high resistive and may not allow sufficient current flow to trip a 20 amp circuit breaker, it only takes like 50 milliamps of current to cause your old ticker to go bonkers OUCH. Another factor is the electrical utility service has its Neutral bonded to mother earth for a common zero reference and water and mother earth (although poor) either one can conduct electricity.
John T
buickanddeere
04-01-2008 10:25:46
The 800MW, that's over 1 million HP 24,000volt generators here are water cooled. The generator conductors are hollow and have demineralized water pumped through them.
I've seen the 250 volt DC excitation brush gear and conductors soaking wet with condensation from the air coolers during humid heat waves. Runs fine for days at a time.
paul sebek
04-01-2008 10:10:58
Actually water itself is a rather poor conductor. It's the impurities like salt, lime, etc, that are often in it that increase its conductivity. You're water and floors must be pretty clean. Electricity goes the route of least resistance. The water still has more resistance to the flow of electricity than the metal wire cord which is virtually zero. Now if the extension cord wasn't plugged in to the pump and just dangling in the water you might have a problem. Usually the fuses/breakers go first since thats the point of having them. Also make sure to pull the extension cord plug from the outlet and not at where the extension and the cord are connected even if they are out of the water. If the floor, plug, and you are still wet you could become the rest of the circuit when you disconnect the pump from the extension cord. Ouch!
coloken
04-01-2008 09:56:01
Water is not as good a conductor as most think. A little salt or acid in it will increase its conduction. Just don't put your finger in the water--its plenty good enough conductor to get you.
