Pto driven generators.
Paul Stanley
12-27-1998 01:18:43
What is the pto rpm required for generators that run off the pto? My trator has 540rpm.
Paul Fox
12-27-1998 04:46:44
 Re: pto driven generators. in reply to Paul Stanley, 12-27-1998 01:18:43
I believe you will find that PTO generators are available in either of the common PTO speeds: 540 or 1000 RPM.
Paul Chambers
12-27-1998 20:16:24
 Re: Re: pto driven generators. in reply to Paul Fox, 12-27-1998 04:46:44
Does the generator mount on the 3 pt or do you back your tractor up to it , sorta like a cow to a Bull Durham sign???
Paul Fox
12-28-1998 04:05:21
 Re: Re: Re: pto driven generators. in reply to Paul Chambers, 12-27-1998 20:16:24
Most mount directly to your three point. It is possible that some of the over 10KW units might be on "sleds" due to the size, I'm not sure.
Wayne
12-28-1998 15:40:00
 Re: Re: Re: Re: pto driven generators. in reply to Paul Fox, 12-28-1998 04:05:21
neighbor has one that is built with wheels it is a larger unit for hog confinments
Slow Poke
12-30-1998 20:20:24
 Re: Re: Re: Re: Re: pto driven generators. in reply to Wayne, 12-28-1998 15:40:00
At both farms were I work they have generators mounted on trailers. When the need arises they just drop the hithch pin in and hook up the pto and they are ready. We ran into a 'problem' a while ago when the tractor that they needed to use on the generator had a problem and could not be switched to 540 rpm from the 1000 rpm. After a little quick thinking they grabbed the pto shaft off from the bale chopper which is 540 on one end and 1000 on the other. Whith it set up that way the tractor runs at a little over an idle so it is quiet and easy on fuel while still putting out the needed power. Works great for running the welder and such lesser needs but when they need to run the whole farm during a power outage they still use it on 540.
Lee
01-05-1999 15:00:35
 Re: Re: Re: Re: Re: Re: pto driven generators. in reply to Slow Poke, 12-30-1998 20:20:24
Who sells these PTO generators?
Jim
01-15-1999 20:01:02
 Re: Re: Re: Re: Re: Re: Re: pto driven generators. in reply to Lee, 01-05-1999 15:00:35
A company called Northern sells one.
Their web site is a bit weak but you can order a catalog from them. Its got a lot of "handy-man" stuff in it, I enjoy browsing though it.
Link
Cheers,
Jim
DY
12-31-1998 06:58:29
A lot of guys use those PTO adapters for generators. Work good.
Works almost as good as my 540RPM mower running on
1000- cuts smooth!
Another thing to consider. If you have a PTO generator, you don't have to buy the engine.
Can get a bigger generator for less cost.
