Tool Talk Discussion Forum
LP Tank Size?
Glenn F.
03-31-2008 10:22:13
Anyone know the size (# of gallons) a 100# LP tank is? I am considering using it for an auxilary air compressor tank.
Thanks,
Glenn F.
thurlow
04-01-2008 11:58:55
 Re: LP Tank Size? in reply to Glenn F., 03-31-2008 10:22:13
Inside diameter is 14.5 inches; 36 inches tall..... excluding the rounded ends. 25.73 gallons..... excluding the rounded ends. Someone who paid more attention in class will have to figure the ends..... ....
flying belgian
03-31-2008 18:59:32
I went with a 110 gallon bubble tank. hooked it in with the 30 gallon compresser tank for a total of 140 gallon air tank. With that much tank capacity I get by with a small compressor.
guido
03-31-2008 12:20:00
Hello Gleen F
From my calculations a 100# propane tank holds 23.52 gallons. 1 gallon of propane weight 4.25 lb.
So 100:4.25=23.529 gls.If the 100 lb.capacity is at 80% total capacity then the tank would hold an additional 4.705 gls.for a total of 28.234 gls. Guido.
Tom from Buckeye Lake
03-31-2008 11:42:35
For a cylinder:
Volume = (Pi x R squared x L) / 231 = gallons
Where:
Pi = 3.1416
R = Radius
L = Length
231 = cubic inches in a gallon
Bob
03-31-2008 10:53:37
They are rated @ 23.6 gallons. You only fill propane tanks to 80%, so I'm GUESSING they hold 23.6 gallons when filled 80% full, about 30 gallons when 100% full.
Circus
03-31-2008 10:49:16
Think about 23 gal. You should install a relief valve.
