Tool Talk Discussion Forum
Chain link posts
Bus Driver
03-30-2008 06:25:54
Some instructions advise setting the posts and then cutting to length. Others say to set the posts to the proper depth initially. I will be working alone, no helper available. What was your experience with the post setting?
CNKS
03-30-2008 16:28:15
 Re: Chain link posts in reply to Bus Driver, 03-30-2008 06:25:54
Set to proper depth -- be sure to allow for the top rail if you are using one.
Fawteen
03-30-2008 12:30:47
I did chainlink semi-pro (worked for a company) for a couple of years in SC. We drove 'em to height, but the part of SC I was in was mostly sand anyway.
Up here in Maine where bedrock can be anywhere from surface to 6 feet down, 2" of topsoil over 2' of gravel is common and conditions just basically suck, I use a combination: Drive 'em to depth or as deep as I can, cut 'em to height with a pipe cutter.
First job I did up here, feller wanted to know how much concrete I was gonna need. "None.", sez I. Took me a while to convince him that all the concrete was gonna do is give the frost something to grab onto and heave the post out of the ground. Told him if that fence moved more than an inch on any post, I'd reset the whole thing in concrete for free.
Been 15 years, ain't been back...
bva
03-31-2008 12:15:22
 Re: Chain link posts in reply to Fawteen, 03-30-2008 12:30:47
that makes life easy. I agree with this approach
J.C.in AZ.
03-30-2008 09:58:12
Setting to the depth you want is vertually impossible in most places in my area of Arizona. Rocks ,Caliche and Sandy Soil all spell a "Loose" Post here. Premixed Mortar Mix and a Dewalt Cordless Reciprocating Saw are my answer to a solid Post setting. We use a 72" Post set about 18"deep if possible, pour Pre Mixed Concrete around Post ,cut Tops off Posts with Reciprocating Saw for 48" Chain Link and Top Rail. Cordless Tools have made work so much easier don"t you think?
jose bagge
03-30-2008 09:41:41
I use a T-post driver, and drive them to proper height.
Dennis V
03-30-2008 08:25:41
It works very good to dig the hole 6 inches short and pound the post in to height. Then add concrete for stability/strength for the life of the fence.
paul sebek
03-30-2008 08:03:06
Set the posts to height. Saves an extra step and cuts down on possible mistakes.
Sid
03-30-2008 06:34:59
Setting them to the height I want usually works best for me.
