Tool Talk Discussion Forum
Chainsaw stalls out....
RoySC
03-30-2008 06:14:28
Recently had a tree get knocked down from high wind, pulled out my chainsaw, a Homelite XL 12 which had been sitting idle for the last few years, to take care of business. Put in new fuel (gas / oil mix) and got it started..... . :-). Appears to idle fine, but when I go to cut and throttle some gas, it stalls out. One pull and it cranks right back up. My next step is to clean the carburator...looking for a diagram. Any other suggestions other than letting the tree rot in place... :-).
Thanks.
BillW
04-09-2008 13:50:03
 Re: Chainsaw stalls out.... in reply to RoySC, 03-30-2008 06:14:28
Tell me the make of the carb. and I can provide the Diaphragm & Gasket Kit, the Fuel Line and Filter.
I have most any part for your saw.
Bill
Jlmtractor
03-31-2008 13:06:42
hey roy in sc where you located in sc my area of southern kershaw county had some recent high winds called a tornado. sorry to change the subject just wondering where you are located at.
RoySC
03-31-2008 17:36:22
 Re: Chainsaw stalls out.... in reply to Jlmtractor, 03-31-2008 13:06:42
I'm in Berkeley County, outside Summerville. We experienced some high winds in my area, but not what I saw you had to deal with. Hope you made out okay!!
Tim B from MA
03-31-2008 09:31:37
Sometimes just spraying the inside of the carb with choke and carb cleaner does the trick. My father in Law brought home an old XL that had not been run in years and would not start. That is all it took.
CH(upstate,NY)
03-30-2008 15:21:16
This was sent to me by a frequenter of this site, "jdemaris". I work with his son.
CH(upstate,NY)
03-30-2008 15:23:06
 Re: Chainsaw stalls out.... in reply to CH(upstate,NY), 03-30-2008 15:21:16
I cut my teeth on an XL12, blue one.
TimV
03-31-2008 11:16:00
 Re: Chainsaw stalls out.... in reply to CH(upstate,NY), 03-30-2008 15:23:06
I cut my big toe on a Super XL!
JT
03-30-2008 13:50:06
You might open the high speed jet 1/2 turn, see if that will get you running. That is a little trick that will work sometime if you have one that will not run, but stumble on acceloration.
Jim
don in ohio
03-30-2008 11:02:55
roy, check the muffler. mud duabers love to plug them up. be sure to take it all the way apart, the screen needs a small brush to clean it good.
don t-9n180179
03-31-2008 02:59:38
 Re: Chainsaw stalls out.... in reply to don in ohio, 03-30-2008 11:02:55
I 2nd the exhaust. Could also be a clogged spark screen.
HTH..... don t. .....
Bret4207
03-30-2008 06:19:25
Chances are it's a clogged fuel filter, collased/deteriortated fuel line or varnished carb not letting emough fuel flow. Also possible the vaccum ports are clogged enough to not let the diaphram work. A dried out diaphram will do that too.
Carb kit, fuel line and filter should fix it.
