Tool Talk Discussion Forum
compression/leak down testers
BobPa.
03-29-2008 21:26:28
Which is better to determine the condition of the rings,valves etc. A compression tester or a leak down tester? Reason I ask is I own a compression tester I've used on my truck and tractors but I saw a leak down tester for sale and have never used one. Thanks
Buzzman72
03-29-2008 22:48:05
 Re: compression/leak down testers in reply to BobPa., 03-29-2008 21:26:28
The easiest way to explain it is that a compression tester will tell you IF you're losing compression, while a leakdown tester will tell you HOW MUCH and where it's going. With a leakdown tester, if you hear it primarily in the intake, your problem is intake valve(s). If you hear it leaking into the exhaust, your problem is exhaust valve(s). And if you hear it leaking primarily into the crankcase, your problem is ring seal.
Both are good diagnostic tools to have, and one pretty much just complements the other. As far as which is better, it depends on your point of view.
BobPa.
03-30-2008 08:53:26
 Re: compression/leak down testers in reply to Buzzman72, 03-29-2008 22:48:05
Thank you Buzzman. Now I understand. Think I will buy one. Bob
