Tool Talk Discussion Forum
Air Compressor Cut-Out Switch
Glenn F.
03-28-2008 01:29:08
My back up compressor cuts in just as it should, but it will not cut out unless I tap the switch (with a screwdriver). I have not used this compressor all winter, but with the coming of warm weather I'll be doing bigger jobs and it'll be used again.
I have not yet taken the cover off to look at things. Can this problem be corrected by filing the points?
I might add, the switch is only about three years old, is wired for 220, and on a 1.5 hp motor. The one on my main compressor is much older and working just fine.
Thank you,
Glenn F.
John T
03-28-2008 12:12:04
 Re: Air Compressor Cut-Out Switch in reply to Glenn F., 03-28-2008 01:29:08
It may help but the problem is once that nice shiny silvery coating is removed they can stick or burn easier next time. Id first try a less abrasive clean/buff/polish and then some electrical contact cleaner followed by a good clean up n drying n maybe light lube the spring n trip n hinge assembly area so all is good n free n smooth. If the points continue to burn n stick a new switch isnt all that expensive and perhaps the exisitng one isnt high enough current or motor HP rated ??
PS if I had a sticking pressure switch Id make sure the high pressure pop off valve is functioning!!!
John T
Greenday
03-28-2008 11:59:37
Just remember that wd-40 IS flammable, I know a guy who used it to loosen up a dry bearing on a well pump motor and when he kicked the pump on he lost his eyebrows.
Gary from Muleshoe
03-28-2008 04:08:04
Glenn I had the same problem on my Sears 220v compressor. I took the cover off and spayed it with a little WD40 and it works like a new again. Gary
mike
03-28-2008 09:53:50
 Re: Air Compressor Cut-Out Switch in reply to Gary from Muleshoe, 03-28-2008 04:08:04
sounds simmilar to the pressure switch on my well pump except mine would mess up on the lo pressure side. A points file and a shot of PB blaster has solved the problem.
unplug/shut breaker off first.
don't ask how I know this....
