Tool Talk Discussion Forum
Tecumseh Solid State Ignition
Rick J.
03-24-2008 07:21:55
I have a 1969 Sears Suburban 12 garden tractor with Tecumseh engine, HH 120, with "solid state" ignition system. It has the starter/generator combo. I need the magneto (part that fits around the crank) and the "pulse transformer" (ignition coil). Anyone know of any sources for these two parts? I was told they don't make them anymore.
Jerry Coulter
03-29-2008 07:43:20
 Re: Tecumseh Solid State Ignition in reply to Rick J., 03-24-2008 07:21:55
Welcome to the no-spark Tecumseh club!! Check out home.earthlink.net/~edstoller. You will find how he repairs failed components. Supplies are available. There is also an outfit named Overnight Solutions who sells a retrofit system. Link
jdemaris
03-24-2008 16:01:37
There are two completely different setups that were used on the same engine. All depends if it has a flywheel alternator or not. The non-alternator one-piece module was the first to be eliminated, than later the other. Years ago when I worked for a Deere, Wisconsin, Bolens, and Tecumseh dealer, we changed many over to breaker-point ignition - but that was 30 years ago. Since then electronics have advanced, I suppose you could make something fit - like the little Magnetron module from a Briggs, or an Atom one-piece "fits all" module.
Robert Jasa
03-24-2008 10:04:16
There ia website: WWW.perr.com out in Washigton state. He does small engine repair. Log into his forum and I know he is an expert on Tecumseh engines. I'm sure he can help you. Bob
JT
03-24-2008 08:56:16
Rick,
One of the parts has been no longer available from Tecumseh. I think Kent from SE Missouri has done a little experimenting and has done some fixes for this.
Jim
