Tool Talk Discussion Forum
Bolt Removal
Joel Cassell
03-23-2008 13:01:19
I have a servis rear scraper blade that I want to clean up and paint. The bolts that hold the cutting edge onto the molboard are very rusty and loose. I would like to remove them and replace with new bolts. Obviously I am not having much luck getting them out. Would would be the best way to cut them off? Angle Grinder? Get me a cutting torch (never used one). Cold Chisel? There are about 10 of them, so its not a huge job but I could see it getting time consuming.
Thanks,
Joel
Sparktrician
03-25-2008 18:20:33
 Re: Bolt Removal in reply to Joel Cassell, 03-23-2008 13:01:19
YOU NEED A TORCH!!!!! !! If you are messing around with tractors and the like much at all, a torch is indispensable. Either cutting or heating, VERY VERY handy. Dont know what i would do without mine. Also, get a good one...Victor and oxweld were always good. Some used are cheaper to buy and better outfits to use..
jose bagge
03-23-2008 19:01:44
Both you and RichZ need a torch! The old "blue wrench" is exactly what you need here!
Joel Cassell
03-23-2008 18:11:00
Thanks everyone. I am going to try heat them up, and take a pipe wrench and see if I can twist them off. If that doesn"t work, I"ll try the cut off wheel on the angle grinder.
Joel
El Toro
03-23-2008 17:11:34
Have you tried heating them red hot then see if the nuts can be removed. Hal
flying belgian
03-23-2008 16:41:45
If you have a welder you could just tack the bolt head and then spin the nut off. than pound the bolt out. that will break the weld loose.
Glenn F.
03-23-2008 14:46:02
If there's room to swing it, a three pound hammer and a GOOD cold chisel will make short work of those bolts.
Glenn F.
Ken Crisman
03-23-2008 13:33:01
I'd say now's the perfect time to buy a cutting outfit & learn to use it . Those hot wrenchs can be very helpful when it comes to being a tractor owner .There's a never ending purpose for them . God bless, Ken
dave2
03-23-2008 13:08:37
Perfect excuse to buy a 4" angle grinder and some cutoff discs. Clamp vice grips on one side to keep them from spinning and slice them off.
Dave
msb
03-23-2008 17:46:05
 Re: Bolt Removal in reply to dave2, 03-23-2008 13:08:37
I second the thin cut off wheels on an angle grinder.Takes no special skills like a torch does and no welding or heating involved.
