Tool Talk Discussion Forum
Torpedo Tune-up
Glenn F.
03-23-2008 11:43:31
It appears winter MAY be ending.
I have a 100,000 btu Reddy Heater I bought new eighteen years ago. I have used it every winter since. It serves me well.
That said, it does seem it may start a littlw harder than it used to. At times it pumps out quite a little #1 diesel fuel prior to firing. What is the tune-up procedure for these machines?
Thank you,
Glenn F.
Charles (in GA)
03-23-2008 15:52:34
 Re: Torpedo Tune-up in reply to Glenn F., 03-23-2008 11:43:31
Was having problems with my 85K model this winter till I discovered that air was not coming out of the little protrusion on the back cover of the pump/filter housing, and found a dirt dauber had filled it up. It had too much air pressure to the fuel nozzle and was consuming too much fuel. I thought it looked brighter orange that usual and that it seemed to use alot of fuel for the little I used it. Worked much better after I removed the rear cover and cleaned out the bleed orifice. Original foam filter bit the dust years ago. I bought a new Briggs and Stratton foam filter element (dry, no oil) and cut it to fit, works great. Also discovered a tiny square filter inside the rear cover, was deteriorated badly, made a new one from some felt. Mine has the spark plug with the very long electrodes, I did close the gap slightly and tested it by disconnecting the air line from the fuel nozzle so it would not siphon fuel, and hooking up the plug to the wire and grounding it. Operated it with the cover off (watch the fan!!) and it worked OK, so I thread lubed the plug and reinstalled it.
Charles
2t2@ia
03-23-2008 14:39:25
It's been a long time since I worked on one, but as I remember: clean the fuel filter, oil the motor, clean and adjust the sparking gap (might be electrodes or a spark plug, depending on the age of the heater), clean the small air intake filter, make sure the fuel tank is clean and has no water. Hope this helps.
oldhousehugger25
04-03-2008 20:38:13
 Re: Torpedo Tune-up in reply to 2t2@ia, 03-23-2008 14:39:25
One other thing I found out the hard way. If you seem to be getting a weak spark, check your ground from the burner unit back to the frame of the machine. This last fall I tinkered and tinkered with the igniter spark plug and finally figured out it wasn't getting grounded. I installed a ground wire and there you go.
