Tool Talk Discussion Forum
auto darkening welding helnmet
ldj
03-22-2008 13:52:20
I just bought a self darkening welding helmet. Instructions say that if stored for a period of time it will need to be left in sun again to recharge batteries. How long is that period of time? Some time I go for 2 or 3 months before I weld anything in the shop. When I need to weld something I may not know it till that something brakes of needs building or what ever. It would be the pits if I need it it won't work because it has been stored too long. If I use it does the arc charge it? How often would I need to sun it to make sure it will work when I need it. Don't think I like that idea.
L.D.
Brian G. NY
03-23-2008 08:59:44
 Re: auto darkening welding helnmet in reply to ldj, 03-22-2008 13:52:20
I keep mine sitting on a shelf with a clear plastic bag over it to keep it clean. It's not actually facing a window but just picks up light from the shop. Been doing that for over two years and haven't had a problem yet.
rockyhawaii
03-22-2008 20:50:33
Keep mine on a closet shelf and it's been ok so far.
IH2444
03-23-2008 09:30:52
 Re: auto darkening welding helnmet in reply to rockyhawaii, 03-22-2008 20:50:33
I have had mine for about 4 years. I keep it in a locker and so far no problems.
Mike in Ohio
03-22-2008 19:44:17
Got mine either Christmas 05 or 06 can't remember. I've used it 5-6 times in that time, it goes back in the box as soon as I'm done. I haven't had any problem with it not being charged when I needed it.By the way after that first cringe because in the back of your mind you don't really trust it till you see it work, you will love it and wonder why you didn't get one along time ago. Good luck Mike
MPK
03-22-2008 19:15:08
I lay mine in the shop window and it keeps it charged.
jhill52
03-22-2008 14:17:08
I keep mine hanging in the shop but not in direct sunlight and it is always readt to go.
NcNE
03-22-2008 14:11:38
I would think that once the battery is charged it should last awhile. It will also charge using the arc. If by chance it needs charged before you weld, leave it sit out while you're prepping the piece to be welded. I wouldnt think it would take very long to charge it enough to get started welding.
ldj
03-23-2008 15:25:28
 Re: auto darkening welding helnmet in reply to NcNE, 03-22-2008 14:11:38
Looks like I was worrying about nothing. I believe if I had read those instructions before buying it I would not have bought it.
Thanks
L.D.
