Tool Talk Discussion Forum
Aluminum tubing stuck
Bill in ME.
03-21-2008 15:59:07
Need ideas on separating two aluminum tubes that have been together to long and have corroded. Is there something I can soak the joint with to loosen? All ideas will be appreciated.
Bill in ME.
03-22-2008 17:28:46
 Re: Aluminum tubing stuck in reply to Bill in ME., 03-21-2008 15:59:07
I'm trying T_Bone's vinegar suggestion first. If that doesn't work, I will do the wax trick and if that won't work out comes the cutting wheel. Thanks all for the ideas. I'll let you know the outcome.
Bill in ME
Bill in ME.
03-22-2008 17:28:32
Bill in ME
JoeK(WI)
03-22-2008 08:21:43
Warm it gently(heat gun/blow dryer)melt paraffin or candle wax into the joint,like sweat soldering copper.A hose clamp tight on the tube will give you something to tap gently on.
jose bagge
03-22-2008 06:10:06
Bike seat post?
See this a lot on aluminum bikes. do you need to keep the peices, or is one expendable?
You could do this- take a whiz wheel and cut a slot down the outside peice. This should loosen it, and also allow some penetrant in if needed. very light heat on the outside tube would also help. When reassembling, use a hose clamp over the slot- or another suitable clamp.
jose bagge
03-22-2008 06:09:47
Bike seat post?
T_Bone
03-22-2008 00:15:34
Hi Bill,
I'd use vinegar and it'll take a couple days at the least and if a tight joint, maybe several weeks of soaking.
T_Bone
