Tool Talk Discussion Forum
'93 Bonneville Runs Good
Glenn F.
03-21-2008 08:29:11
I thought I'd post back regarding my Bonneville woes which many of you gave helpful advice in solving.
As you may remember, it would not stay running, showed "check engine," brake chime was on, and had limited brakes.
The brake problem proved to be a leaky line to the right rear wheel (I have now replaced most of the brake lines under the car).
The engine problem was the map sensor. Early on I had cleaned it with carb and choke cleaner, with slight success. I later cleamed it with ether and it now runs very well. Carb/choke cleaner leaves an unacceptable residue.
The ole' girl now has a new lease on life.
Thank you,
Glenn F.
AndrewFromNS
03-21-2008 09:23:56
 Re: '93 Bonneville Runs Good in reply to jdemaris, 03-21-2008 08:29:11
Why couldn't it be the MAP Sensor?
Glad to hear you've got your Bonne workin' good again. A friend of mine drives one...has ~300,000 km on it, still runs beautifully. It's destined to disappear soon, though...suspension is shot, A/C is shot, floor is starting to go...cost of repair is almost the cost of a good used car.
AR
bradk
03-21-2008 10:18:58
 Re: '93 Bonneville Runs Good in reply to AndrewFromNS, 03-21-2008 09:23:56
Andrew,Cause there's nothing to clean on a MAP sensor.Any carb cleaner would destroy unit.
bradk
03-21-2008 08:56:16
 Re: '93 Bonneville Runs Good in reply to Glenn F., 03-21-2008 08:29:11
Must mean MAF(air flow sensor?
Glenn F.
03-21-2008 13:28:12
 Re: '93 Bonneville Runs Good in reply to bradk, 03-21-2008 08:56:16
Yes, I think it is the MAF sensor.
Glenn
