Tool Talk Discussion Forum
Tire Patch Glue Dries Up
Glenn F.
03-19-2008 10:08:01
I don't often patch tires (tubes) so my carefully closed/sealed bottle of "glue" gets thicker and thicker, eventually ending up in the trash can, as it becomes unusable.
Is there a type of thinner I can use to extend glue life?
Thank you,
Glenn F.
Davis SC
03-20-2008 22:45:36
 Re: Tire Patch Glue Dries Up in reply to Glenn F., 03-19-2008 10:08:01
I am no chemist, but I think that the solvent(s) are something like Tolulene or Xylene.
mike
03-20-2008 12:01:47
I ran a tire service truck for 10 yrs. Took me awhile to figure out when you remove the brush from container and it strings out from brush to container it's time to chuck it out. aproperly prepped tube, good glue and a warm patch (stick it in your pocket, especialy this time of year) will give you near 100% success rate. use compromised glue and success drops drasticaly.
My suspicion is the glue goes bad not from improper sealing but from the rubber contaminants the brush picks off the tube and transfers back to container of cement.I think if you use a clean brush for your cement every use you have better luck. I get the brushes at the hardware store in the plumbing dept where the soldering stuff is kept. good luck and remeber do it right the 1st time or you'll jes be back again
Fred Martin
03-20-2008 10:39:54
That John Garners got more tricks up his sleeve than a card shark! But, if you use his method and get it too thin...you can probably restore it with a little viagra. ohfred
RayP(MI)
03-20-2008 02:20:12
Have the same problem with the glue used to glue plastic plumbing! Once it is open, it seems to be a lost cause!
Jim in N M
03-19-2008 16:48:29
Hi Glen, I was told to always store these items up side down,like auto paint hardner etc. Jim in N M
dr sportster
03-19-2008 13:04:07
For Seal-All I used to keep the tubes in a jar with a thinner soaked rag.I also used to keep new unopened for emergency because it usually still dried out after a long time.Then it was just open and try to save the next one.I still have the jar with one more unopened Seal-All.Finding it is another story.
John Garner
03-19-2008 12:14:51
Glenn --
Plain naptha, usually sold by hardware and paint stores as Varnish and Paint Maker's Naptha, used to do that trick.
John
Jim in Ma.
03-19-2008 11:56:52
You have nothing to lose, I would try a little rubbing alcohol???
Bus Driver
03-19-2008 14:35:34
 Re: Tire Patch Glue Dries Up in reply to Jim in Ma., 03-19-2008 11:56:52
Rubbing alcohol is mostly water. It will ruin the cement. I would try some Berryman's B-12.
