Tool Talk Discussion Forum
manure measuring device
jose bagge
03-17-2008 16:50:14
When the spare touches ground, it's time to run the "Free Fertilizer" ad....
Free Image Hosting at allyoucanupload.com
WalJohn
03-20-2008 14:23:07
 Re: manure measuring device in reply to jose bagge, 03-17-2008 16:50:14
TG wrote Where are you in VA, Jose? I'm near Danville
I am 4 miles west of Gretna, about 20-25 miles north of Danville.
tg in VA
03-19-2008 15:29:25
Where are you in VA, Jose? I'm near Danville and have few takers @ $5 per 8' scoop. My pile is about 2 feet shorter than Mt Rogers and growing!
jose bagge
03-19-2008 18:14:30
 Re: manure measuring device in reply to tg in VA, 03-19-2008 15:29:25
I'm in good ol' Fredburg, home of disgraced University Presidents! I charged just enough per load to pay for the deisel to load it...and then guys strted bringing their own tractors over when I couldn't load it fast enough!
Poop pile might be the only part of the farm turning a profit...If the rain ever let's up, I may get this thing whittled down to nothing.
Been to Danville many times...used to be the DM for the Sears Auto Center there.
Billy NY
03-19-2008 13:51:56
Sure would be nice if they did strip it out of the stalls !
I took the liberty of trying my hand at making compost at the horse farm, don't have a lot of room, tiny little tractor, but I was able to make a big pile of finely composted material.
If one has the room, you get enough rain or have a water source if it is dry, have a loader on the tractor, and are handy with same, it can be done. If I had a 920, 930 size cat loader, it would be relatively easy to do. It's a lot of work for the little tractor like this, have to keep the pins greased.
It sells in this area, and the neighbor does it as a very successful seasonal type business. I really enjoyed the seat time and would like to get some equipment to do it, when we had 30-40 horses, there was no short supply of manure.
The biggest thing I found important was using consistent bedding, most preferrable for this compost was a pine sawdust, we used to get oak, and other hardwoods, pine seems to break down the easiest, or the bagged shavings and similar wood products. Keep the nitrogen up and check the pile temperatures, turn them regularly to do the aerobic type composting, it worked very well, I could turn over batches in 6 months doing it like this. Feeding the best quality hay also helps, when we had crap hay it gets mashed into the manure, source of carbon and it takes longer to break down, chokes up the material too much for my liking, best when they eat every bit of it, and when the d$mned help don't toss poly bale twine in the manure, jerks contaminated a big compost pile with it on me, it's probably good that I don't do much up there any more.
Downside, it's not my place, my father and wife own it, not my tractor, I don't think they saw the value in doing it, but me having spent a lot of time on heavy equipment, saw it being easily created and a product that can bring good seasonal revenue, spring and fall, offsetting the cost of running the place. I've had that little tractor on stockpiles of manure 2x as high, never took a photo, got too high and gave a bunch to the neighbor. Stopped doing it, but for anyone who has enough room, a loader and time to do it, well worth doing, people around here buy everything the neighbor composts, we used to give it all to him, and watch him make money off it, when we should have been doing it all along, generation before me just don't see the value in it, so I gave it up, had I the equipment I'd be in that loader all day long making money off it, sells $25-$35 + per cubic yard.
third party image
JML755
03-19-2008 06:59:16
Now if you could figure a cheap way to put the manure into the TANK of that vehicle, you'd be driving a Cadillac :)
dave2
03-19-2008 04:55:32
If you've got high ground water and tree huggers (worse yet, a combination of the two) it may not be as simple as piling it up.
Kirk Grau
03-18-2008 13:04:07
I take it that you have not found a spreader yet.
Kirk
jose bagge
03-18-2008 16:00:41
 Re: manure measuring device in reply to Kirk Grau, 03-18-2008 13:04:07
I'm spreading it all around Virgina! I put a free ad in the "$50 and under" section of the paper for $10 a load, and had 10 takers first day... two guys sHowed up with trailers and their own tractors to load ( one guys case is still here- he's been back 4 times!). The pile is a lot bigger than it looks in the picture!
At this rate, I'm gonna see if I can eliminate the middleman and have 'em take it right out of the stalls every morning!
Kirk Grau
03-19-2008 04:25:11
 Re: manure measuring device in reply to jose bagge, 03-18-2008 16:00:41
Sounds like a pretty good deal. I have been considering modifying a corner of one of our pastures that is accessible to make a compost/stockpile location. This corner is accessible from a driveway so I could get to it in any weather. For now I will have to keep hauling it to the neighbors pile when the fields are wet.
Good Luck,
Kirk
dave2
03-19-2008 00:51:07
jose bagge said: (quoted from post at 16:00:41 03/18/08) I'm spreading it all around Virgina! I put a free ad in the "$50 and under" section of the paper for $10 a load, and had 10 takers first day... two guys sHowed up with trailers and their own tractors to load ( one guys case is still here- he's been back 4 times!). The pile is a lot bigger than it looks in the picture!
Keep them customers happy!!! I'd be washing tractors while they were drinking coffee. I've got a guy that takes all I produce, but have to take it to him and unload it. Not a big deal for the horses at the house because I keep a container on the tractor and he lives 500 meters away. The horses pastured away from the house has a pile that the guy will take but I have to handle it twice. Put out the word that it was free for the taking and had plenty of people come look and not come back. Same people bought from another local. Only difference is they had to move mine about 20 feet in a wheelbarrow to put it in the trailer. Going to advertise it for sale and try to get a couple of kids to bag it and keep the money themselves.
If that don't work, guess I'll be in deep manure eventually or haul it myself.
Dave
old
03-17-2008 17:50:17
If you did that to my manure pile that thing would be on its roof.
