Tool Talk Discussion Forum
Replaceable york rake tines?
gun guru
03-16-2008 17:13:56
I have thought about making my own york rake, small 54" or so. Is there a place to buy the curved tines? I checked the Northern tool website and no luck. I could make one of these up in day at work, (on my time, not the bosses) and save $200 doing it.
deadeye012
03-20-2008 07:10:11
 Re: Replaceable york rake tines? in reply to gun guru, 03-16-2008 17:13:56
I think Tractor-Supply has them if you are close to them...JB
ZacsDad
03-17-2008 08:46:53
Try Agri-Supply (www.agrisupply.com) They have 3 types:
1 -hole 1"x5/16" p/n 52646 $2.09 ea
2 -hole 1"x5/16" p/n 33913 $2.99 ea
2-hole HD 1.25"x3/8" p/n 46796 $5.99 ea
I bought a bunch of the one-hole type to refurbish my rake. Wasn"t an exact fit but they seem to work ok. Their phone is 800-345-0169
T_Bone
03-20-2008 09:21:36
 Re: Replaceable york rake tines? in reply to ZacsDad, 03-17-2008 08:46:53
Hi ZD,
How hardy are the tines in real use? Do they hold up well?
What I'm wanting to do is to use them to rake small surface rocks into a pile then scoop them up with a FL to load. Spacing of tines would be every other inch or less.
Good idea or am I wasting my time?
T_Bone
Tines
03-16-2008 20:07:19
A truck spring shop could make them up but they probably won't be cheap. Sometimes it's a lot cheaper to just buy an implement than make one. I wouldn't think a 54 in. would be that pricey.
Don L C
03-16-2008 18:42:22
You will have all most as much in, building it as you can buy one at Tractor Supply..... ..
Scott.ID
03-16-2008 18:04:07
I get replacements at the local tractor supply for 12.00 each. Mine is a Land Pride LR 15, link below.
Scott
RayP(MI)
03-16-2008 17:31:47
I suspect they are made of a pretty good grade of tempered spring steel. Might find yours end up bending way too esaily, unless you have access to appropriate material.
