Tool Talk Discussion Forum
How do they bend channel iron?
Willy P
03-15-2008 19:53:48
How do they bend channel iron like on the New Holland rakes? I have seen a lot of iron that is bent and I have always wondered how it is done. Is it made in that curve or is the iron bent after it is made? Just curious because it is smooth. Thanks
TomH in PA
03-16-2008 07:19:36
 Re: How do they bend channel iron? in reply to Willy P, 03-15-2008 19:53:48
The trick is to bend it around a form while it's hot, so the inside stays the same length and the outside stretches. If you try to bend it without the form the inside will be crushed.
Bending channel
03-15-2008 23:39:39
They make structural rollers for channel and other shapes. I beams can be curved as well. Sometimes just heating the right way will give you a curve without any presses or rollers.
Bob Huntress
03-15-2008 21:59:16
I usually grab both ends and pull toward the middle. You want make sure that you do this slowly, as I often snap them when I pull to fast.
Uncle Ernie
03-16-2008 07:37:32
 Re: How do they bend channel iron? in reply to Bob Huntress, 03-15-2008 21:59:16
My you are strong. When I bend it I wedge one end and pull on the other. That way I only leave fingerprints in one end!
Bob Huntress
03-16-2008 10:46:05
 Re: How do they bend channel iron? in reply to Uncle Ernie, 03-16-2008 07:37:32
third party image
You could always get one of these for all your iron bending needs.
Roger in Iowa
03-15-2008 19:59:18
Deere factory I worked in bent it hot. After heating, it was placed on a machine called a "bulldozer" that bent the material around a form or tool designed for the shape you wanted.
Roger in Iowa
