Tool Talk Discussion Forum
Cleaning tools in toolbox
Roger in Iowa
03-15-2008 10:05:43
Anyone have an easy or easier way to clean hand tools?
I am using a container of water and dish/laundry soap and they are difficult to clean. Only do it every few years, until I can't stand it any longer.
I do not have a parts washer.
Anyone used a dishwasher and lived to tell about it? Other ideas?
Roger in Iowa
greygoat
03-17-2008 09:38:41
 Re: Cleaning tools in toolbox in reply to Roger in Iowa, 03-15-2008 10:05:43
Starting Fluid really works great to spray down
dirty tools, then wipe with a clean rag--but
probably not very safe or envrionmentally friendly
dave2
03-17-2008 06:14:03
spray w/ WD40 and let them set a while (you be the judge by trial & error) before wiping them off. Save/reuse the rag until it gets too nasty. Clean as you go is the best practice though.
Dave
Spook
03-16-2008 12:14:50
I just wipe them off with a rag. Probably leaves a little oil on it that way.
glennster
03-16-2008 05:27:27
i use the parts washer to get the grease off any tools before they go back in the box. you can pick up a couple gallons of parts washer solvent, keep some in a metal paint can with a lid, when you clean em, just dunk them in the can , stir it up some then wipe the wrench or whatever off with a shop rag. drys quick, cleans well..
2t2@ia
03-15-2008 19:28:03
Might be worth a try to let them soak in the soapy water for an hour or so. Sometimes that softens the "dirt" and it wipes off easier.
WantACaseLASomeday
03-15-2008 18:03:27
[quote="Roger in Iowa"](reply to post at 12:05:43 03/15/08) [/quote
We used to tell wet-behind-the-ears rookie policemen that the best way to clean a stainless steel sidearm was to take the grips off and put it in the dishwasher with a cup full of regular dishwasher soap like you use in the sink.
Of course the suds usually foam out the vents and cover the kitchen floor and you have to run it empty something like 19 times to get rid of that foamy soap.
1936
03-15-2008 15:48:42
KETCHUP--Any brand-- submerge the chrome tools in the red stuff. Keep checking to figure out the lenght of time needed. Leave for a week and come back-not good on the tools--wash off with water and spray down with WD 40 the few things I have found wd 40 good for. Better than wifes dish washer.
Bernoulli/OZ
03-15-2008 14:25:57
Roger in Iowa said: (
Roger in Iowa
There was a thread some time back about washing shop rags in the washer. The general consensus was that it wasn't worth the domestic problems created.
My knives are important tools to me. I never put them in a dishwasher. My hand tools are just as important. I wouldn't risk them in such a caustic environment.
Perhaps if you attached a rag to your toolbox, you could wipe the tools as you return them. Remember the danger of oily rags left around!
PJH
03-15-2008 19:28:08
 Re: Cleaning tools in toolbox in reply to Bernoulli/OZ, 03-15-2008 14:25:57
I had a friend who had a repair shop. His wife would pre-wash the shop rags at the gas barrel, then run them thru her washing machine. She forgot to add soap one day, raised the lid, and the lid switch set off the fumes. It blew the prehung bathroom window out into the front yard, frame and all, and didn't break the glass. Singed her sweater a little - no other injuries. Hubby thought the local quarry had set off a blast until he heard her hollering. . .
Goose
03-15-2008 13:46:23
I gotta tell this. Once when I was in the Marine Corps, the carburetor on my car needed cleaning. I scrounged around at work and found a five gallon can half full of a water soluble paint remover.
I cobbed onto it, took it back to the barracks, and used it like regular carb dip. It worked just as good as any carb dip, and a buddy of mine was hanging around while I worked. When I was at the point of assembling the carb, the half full bucket of paint remover was still sitting there. Since I was done with it, my buddy asked if he could use it to clean his tools. I told him to go ahead as I was just going to dump it somewhere where I could get away with it anyway.
My buddy emptied his tool box into the bucket and we bs'd for a half hour or so while I put my carb back together.
When my buddy went to retrieve his tools, he found all of his plastic handled screw drivers had the handles gone.
Jim in Ma.
03-15-2008 13:28:49
I can't remember ever washing tools,I do wipe them down with a rag every time I use them. For special test equipment I spray with citrus cleaner and wipe clean with shop towels.Also at the end of every day "ALL Rags" and towels go out of the shop.
Gun guru
03-15-2008 11:11:38
Use mineral spirits, or lac. thinner to clean. Then after they are dry use a light lube like WD40 or silicone spray to prevent rust.
Lanse
03-15-2008 11:07:07
unless they're chrome (or plastic) , i use a wire wheel on the bench grinder, then i spray on some WD40 or motor oil, then wipe it with a rag. Works for me!!
Fawteen
03-15-2008 10:59:07
I work in a sardine cannery. Fishguts and saltwater everywhere, HORRIBLE environment for tools.
Any tools that get used during the day get cleaned and oiled before I leave at night.
For cleaning, I use a foaming citrus-based cleaner. There are several, the one I use is a commercial food-safe product. Spray it on, let it set for a minute and wipe it off. Works great, cleans ALL the crud off.
That's all I do for ordinary hand tools. Ratchets and gearwrenches and such get a light spray of oil.
Been there almost 3 years, and no rust yet.
azharry
03-15-2008 10:41:28
What are you trying to clean off?
soaking in vinegar works good for rust removal
Bob
03-15-2008 10:30:19
Leaving them a little greasy prevents rust!
