Spark plug spark tester
Jerry A.
08-27-2001 07:55:06
Any leads on a "neon" bulb type spark tester for gasoline engines? The type I'm looking for fastens on or lies next to the spark plug wire and flashes if there is a high voltage impulse in the plug wire. My brother told me that Tractor Supply Co. may have such an item. NAPA has apparently quite carrying this tool.
Thanks
ferrell freeman
08-27-2001 18:38:25
 Re: Spark plug spark tester in reply to Jerry A., 08-27-2001 07:55:06
YOU,can get a sparkplug made by AC DELCO the part #ST125 ,looks like a sparkplug with an alligator clip to ground to something . This will work with low voltage and high voltage ignition sysem.
VaTom
08-27-2001 17:38:02
Got an inductive timing light? It does the same thing. Mine says Sears on it.
Big Jake
08-27-2001 08:38:32
I assume you mean for a briggs ? stratton type engine??
www.northerntool.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=35173?prmenbr=6970
Neil
08-27-2001 08:16:14
You may find a typical neon, AC tester will work fine.
put an anegator clip on one lead, and let the other one float.
Mac
08-27-2001 16:44:39
 Re: Re: Spark plug spark tester in reply to Neil, 08-27-2001 08:16:14
Brings back interesting memories when I was a youngster. Used to make a lamp holder(neon bulbs)from Radio Shack.
6 or 8 cyl.
Hook it under dash. Then run wires thru fire wall around plug wires. Was certainly a conversation piece. You could monitor spark constantly, but really had no purpose.
Neil
08-28-2001 08:52:51
 Re: Re: Re: Spark plug spark tester in reply to Mac, 08-27-2001 16:44:39
Almost as much fun as lighting a fluoresent bulb by holding one end when near a radio tower
