Tool Talk Discussion Forum
Jonsered CS2152 Chainsaw Carb Tune Up
tim dick
03-14-2008 07:44:30
Is anyone able to provide the initial settings for the low speed jet, high speed jet, and idle screw (counter clockwise turns from the closed screw closed position). Thanks.
guido
03-15-2008 06:39:29
 Re: Jonsered CS2152 Chainsaw Carb Tune Up in reply to tim dick, 03-14-2008 07:44:30
Hello Tim Dick
Low 1 1/2 turns out. High 1 turn out.
Guido.
JT
03-14-2008 13:28:44
We nromally set a static of 1 1/2 turns and adjsut from there. you goota be real caeful about where you end it up, though, if you get it to lean, it will destroy the cylinder.
Jim
Hotflashjr
03-14-2008 09:00:53
That sounds about right to me. I will double check my manual when I get home from work tonight though to be sure.
LarryinIN
03-14-2008 08:27:26
1 turn out for High and Low should make it run.
