Tool Talk Discussion Forum
Switchable disconnect box
Roy Suomi
03-11-2008 21:12:33
I've got an application where I need to start a 5 h.p. electric motor , probably once or twice a day..Can I get away with using a 100 amp 240 volt single phase switchable disconnect box for this?? I was hoping to not have to get a magnetic starter..I'm replacing a Lombardini single cylinder diesel with an electric motor..
Sparktrician
03-14-2008 15:09:24
 Re: Switchable disconnect box in reply to Roy Suomi, 03-11-2008 21:12:33
If your motor has built in overload protection, (if if does it will have a reset button, most likely on the side of peckerhead) all you need is a disconnecting means within sight of the motor, so yes, your disconect will work IF your motor has overload protection. All the starter is is a contactor with overload protection. I am a electrical contractor, and if you hired me to do it, this is what i would do. IF you dont have overload protection, you can install a starter, or buy a overload relay to mount on your motor. PS, a PECKERHEAD is the wiring box on your motor, if you didnt know that.
John T
03-12-2008 06:27:22
Roy, you realy need BOTH a disconnect PLUS a motor starter with overload protection. The good news is such are available n not all that expensive combined as a single unit called a COMBINATION STARTER. You just need to know the HP and current and voltage and phase/terminals and head to your local electric supply house n ask for a COMBINATION STARTER.
Sure farmer Billy Joe Bob can get by with hanging whats called a safety switch on the wall (he could even use a cord n plug) to serve as the required DISCONNECT and perhaps the motor has internal thermal overload protection?? But a Combination Starter has to be my recommendation
John T Too long retired electrical n NEC rusty engineer
Uncle Ernie
03-11-2008 21:18:58
You can get away with most anything... How LONG is another matter. In truth the answer is No. You need a starter. A manual starter is not real expensive.You said a switchable disconnect, is it actually a manual starter? Should also have thermal overload protection as well as a fused disconnect. You will feel real bad if you burn something or someone up.
Roy Suomi
03-11-2008 21:15:24
I forgot to mention, the motor pulls 26 amps..
