Tool Talk Discussion Forum
2 Stroke Oil Revisited
Slowpoke
03-11-2008 00:17:01
A thrift store I frequent has a dozen quarts of Valvoline 2 Cycle Snowmobile Oil. They want $2/qt, but its been on the shelf for 2-3 months and it's getting summer. Bottle says for injection or premix, racing or family use, flows in extreme cold. Can it be used in a chainsaw? Or is it too thin?
Thanks
JT
03-11-2008 11:05:42
 Re: 2 Stroke Oil Revisited in reply to Slowpoke, 03-11-2008 00:17:01
The oil does not matter how long it sits, it will not go bad, the gas that is added into the oil is bad. Check and make sure it is an ashless oil.
Jim
Slowpoke
03-11-2008 11:48:03
 Re: 2 Stroke Oil Revisited in reply to JT, 03-11-2008 11:05:42
It's an ashless oil per Valvoline. It hasn't sold in several months, and there's no snowmobiles around here. If it good for chain saws, I'm thinking of offering $10 for the lot.
guido
03-11-2008 12:35:21
 Re: 2 Stroke Oil Revisited in reply to Slowpoke, 03-11-2008 11:48:03
Hey slowpoke I would buy it. It will work for you.
Guido.
guido
03-11-2008 06:53:24
Hey Slowpoke
I have been using mobil ouboard 2 cycle oil with the same specs more or less .It will do just fine.
Mix it as needed for the saw.
Guido.
Vern-MI
03-11-2008 04:30:23
It is supposed to work in any engine that requires 11:1 up to 150:1 mix ratios.
