Sandblasting
J-Philippe Bour
08-24-2001 06:45:30
I would like to buy a sandblaster to clean my tractor before painting.I found two models : a siphon-style sandblaster and an other made like a paint gun with a small tank under the gun to put the sand in. Which one do you advise me ?
Mark
08-28-2001 15:56:32
 Re: Sandblasting in reply to J-Philippe Bourget, 08-24-2001 06:45:30
Pressure blasting is the only way to go for large items ...ie car fenders. The siphon type is cheaper and works well on small items, but requires your compressor to work very hard to keep up. The pressure type is much more efficient plus you can buy one for a round $175 (100# one full bag of sand)or you can build one from an old hot water heater ...I did! GOOD LUCK
Kirk
08-26-2001 10:54:18
I agree too. You need a pressure blaster. I completely blasted my W-9 last winter. I used about 1000 lbs. of black beauty (even with trying to reclaim, sift and re-use). You would spend an awful lot of time refilling your sandblaster with a hand held unit.
luke
08-24-2001 10:22:19
i agree, get the pressure tank and use the black sandblasting sand, not the silica sand. the black is easier to work with
Peter
08-24-2001 07:55:41
Niether. A pressure tank unit works best and has a comparible cost at Harbor Freight Tools.
