Tool Talk Discussion Forum
'93 Bonniville
Glenn F.
03-10-2008 20:15:34
I'm doing front brakes (disk brakes) on my '93 Bonniville. I don't do brakes that often as I always use high dollar parts.
Question: The outside pad on both wheels is nearly steel on steel, while the inside ones are probably less than half worn out.
Is this normal? What causes this? I've seen uneven wear before, but this time seems worse than usual.
Thank you,
Glenn F.
Circus
03-12-2008 05:44:49
 Boy, that car's a mess. in reply to Glenn F., 03-10-2008 20:15:34
Boy, that car's a mess. Getting tired of it? I am.
504-2
03-11-2008 17:07:46
 Re: '93 Bonniville in reply to Glenn F., 03-10-2008 20:15:34
jose is right, ASE retired
jose bagge
03-11-2008 06:21:27
Your caliper slides are stuck, and they are locking up in the "on" position. Disassemble the slides, clean well with wire brush, lube with lithium and reassemble....or based on mileage, by a pair of loaded calipers and do the whole thing at once.
hoyle
03-11-2008 06:26:43
 Re: '93 Bonniville in reply to jose bagge, 03-11-2008 06:21:27
Silicone grease is better
jose bagge
03-11-2008 06:32:42
 Re: '93 Bonniville in reply to hoyle, 03-11-2008 06:26:43
Raybestos and bendix might disagree, since the grease they supply is lithium, but some brake grease is silicone as well.
The point is, do NOT use wheel bearing grease or moly lube, as it will migrate under temperature and get all over.
dddd
03-11-2008 09:26:59
 Re: '93 Bonniville in reply to jose bagge, 03-11-2008 06:32:42
they make wheel bearing grease that exceeds 400* F
MarkB_MI
03-11-2008 03:49:28
Just to be clear: Whenever you change out your pads, you should completely remove the caliper bolts and bushings from the calipers and lubricate them with the grease that's made for this purpose. The bolts are usually captive in the bushings; often you have to drive the bolts/bushing out with a hammer and punch. Replace them if they're rusty, otherwise just clean them up and lube the bushings so they slide easily into the calipers. That's about all you can do. Some uneven wear is normal.
Bob
03-10-2008 22:54:55
Are the rotors more rusted (and therefore ROUGH) on the OUTSIDES?
Mark-Mi
03-10-2008 21:18:31
Hi Glen,caliper does not slide on anchor bolts.Slides on bushings.Your problem does not make sense.Piston pushes inside pad against rotor first causing floating caliper to react and move over.Stuck caliper wears inside pad.Inside pad usualy wears more anyway because it contacts first.Mark
jose bagge
03-11-2008 06:27:13
 Re: '93 Bonniville in reply to Mark-Mi, 03-10-2008 21:18:31
wrong...stuck caliper PISTON wears inside pad, stuck caliper SLIDE wears outside pad. Outside pad wear is far more prevelant, since slides are much more exposed that pistons. Happens all the time.
RobMD
03-10-2008 21:04:01
Caliper has to slide freely back and forth. Lube the slide bolts with wheel bearing grease.
Tootters
03-10-2008 20:26:52
grease the slide hardware
