Tool Talk Discussion Forum
roller bearings
jaker2
03-10-2008 16:21:34
I am working on a hydraulic pump that has Orange brand bearings in it. Has anyone ever heard or this brand? I have called a few places and nobody knows anything about them. The numbers on the bearing are Orange 1 -SE 6095A340X36. Does anyone know of an online cross over chart?
jaker2
03-11-2008 08:16:33
 Re: roller bearings in reply to jaker2, 03-10-2008 16:21:34
Thanks for all the replies, but it looks like the bearings are no longer available. I have been told the a Tyrone 973-p pump will bolt right in but so far my searches have turned up nothing.
J Schwiebert
03-11-2008 10:29:16
 Re: roller bearings in reply to jaker2, 03-11-2008 08:16:33
Now there is a description (bolt right in). What model of Tyrone pump/ Tyrone pumps start with the letter P and then go to the number none of which have a 9 as the first number. Since you have the Hydreco apart measure it up as there is a formula and cross it to another brand it is done everyday. Also you are talking to the new Hydreco people which probably does not furnish any parts for the older hydreco pumps. Is this still a pump you shim to adjust it? J.
Jaker2
03-11-2008 10:57:47
 Re: roller bearings in reply to J Schwiebert, 03-11-2008 10:29:16
Sorry J. The number that I give you is a brass lock that sits on the shaft in the hydreco pump. The number for the tyrone pump is 2p-176. Does this number come up with anything? thanks for your help
J Schwiebert
03-11-2008 11:32:44
 Re: roller bearings in reply to Jaker2, 03-11-2008 10:57:47
O. K. Much better. Now the 1P & 2P pumps were the orignal Tyrone pumps when they came over from England. How can I call you and give me a time as well. FYI Tyrone is no longer either.One reason I was downsized. Roller bearing pumps are a cheaper pump than a bushing pump. Everybody made one or two models to be like the competition, but do you have dimension for that bearing? I have some Tyrone roller bearings and I think they have an uncommon brand name as well. J.
j-tex
03-11-2008 06:13:24
Orange is a division of Roller Bearing Co. of America (RBC) as it is known in the B&PT industry.
RBC phone is 203-267-7001
or try United Bearing Co. they are a huge bearing surplus co that buys surplus bearings from Dist and whse"s. 800-421-1252
J Schwiebert
03-11-2008 05:46:13
Well that changes the issue a little as well. Hydreco was under for the count but has seamed to survive. I know Dana was looking at selling some Hydreco when I was doing pumps for Dana's TRP. Do you have the bearing out? I also would not mind knowing how you contacted them at this stage of the game. Thanks. J
mixaplix
03-10-2008 17:41:50
google a bearing place, timkin or whatever most will have a tollfree to call they should be able to cross the number or measure or send them the bearing and they will have one for you
J Schwiebert
03-10-2008 17:09:18
Let us go the other way. Who made the hydraulic pump and what model is it?
jaker2
03-10-2008 17:12:03
 Re: roller bearings in reply to J Schwiebert, 03-10-2008 17:09:18
Hydreco and I don't have the number here with me. I have already went through them and they say the bearing is no longer available.
