Tool Talk Discussion Forum
1/2' air ratchet
jose bagge
03-09-2008 13:16:17
Anyone ever seen one? I bought a bucket o' air ratchets at an auction and one of 'em is a 1/2" drive Ingersol Rand. Other than being painted green all over it works great- but what would you use one for that you wouldn't grab am impact for?
tractormarkb
03-10-2008 06:39:01
 Re: 1/2' air ratchet in reply to jose bagge, 03-09-2008 13:16:17
The Ejector Bars on an Injection Molding Machine are in a tight location and need to be 'tight' but not impacted tight. We use many 1/2" impacts in our shop.
LAA
03-09-2008 18:55:07
I have seen them used to ''POP''(pre-tension) breaks on large electric crane motors on cranes used in pulp wood mills. The advantage the ratchet has over an impact wrench for that type job is the ratchet applies the torque steady and shock free which also makes it a hazard for jerking a knot in your tail if trying to break large stuck bolts.
Dave 2N
03-09-2008 17:10:35
Keep the ratchet head greased; on most of those there is a little "pimple-like" thing that is a grease fitting on the ratchet head. You grease it with a small needle-style grease gun. Ratchet heads will get pretty hot and fail if not greased.
guido
03-09-2008 16:19:24
Hello jose bagge.
I got a 3/8 drive IR, I would watch my knuckles if i were you! Powerful tools. keep the air feeding them at 100# or less, again for the good of your knuckes.
Guido.
Dave 2N
03-09-2008 15:36:38
Tight places where you can't use a gun. What color green is it? If it's OD, it might have been a "Special." That's what I-R called the tools they did for the military.
jose bagge
03-09-2008 16:13:44
 Re: 1/2' air ratchet in reply to Dave 2N, 03-09-2008 15:36:38
it's definitely spray painted green....the way a business would paint something so it doesn't end up in an employee's tool box through "mistaken identity"..
Looks like it might have anyway.... but it's in my box now! $5.00 for the bucket- had 2 3/8", the 1/2, and a air chisel, and they all work!
Dave 2N
03-09-2008 17:08:27
 Re: 1/2' air ratchet in reply to jose bagge, 03-09-2008 16:13:44
Most of that I-R stuff you can get parts for it was from what they called their "Industrial Line." These were a little more quality than some of their "Automotive After-Market Line." A lot of these were throw aways.
trucker40
03-09-2008 14:11:28
You would be surprised at the places you can get them in on cars and trucks.Keep it oiled and it will last.
Kentb of SWMO
03-09-2008 13:54:41
I work on a lot of small engines. I have a 1/4" air ratchet that is about the handiest tool I have.
Kent
Ebbsspeed
03-09-2008 13:49:44
Those air ratchets can reach into places you can't get with an air impact. That's what I use mine for.
CENTAUR
03-09-2008 13:45:17
Many of the air ratchets come in either 3/8 or 1/2 inch drive.So you can get the 3/8inch if you want it. they interchange. CENTAUR
timcasbolt
03-09-2008 13:42:13
When I was buying air tools about 20 years ago, I had a much better inventory of 1/2" sockets compared to my 3/8" sockets, so my air ratchet is 1/2". They run about the same cost, so it's just a matter of what you need.
