Tool Talk Discussion Forum
Starter Boosters cause damage?
Gwiz
03-07-2008 07:02:54
Can using a 200-250 amp starter booster to help start a slow turning diesel engine cause any damage to the wiring/gauges etc.? It would be hooked directly to the positive battery cable.
James
JT
03-09-2008 07:20:23
 Re: Starter Boosters cause damage? in reply to Gwiz, 03-07-2008 07:02:54
If it is a old diesel engine, no. If it is a newer one, probably not. I do know on a Kohler engine with an EFI, if you jump them, you will burn up computor. The use a 355 cca battery and you are using a 225 amp boost. Kohler claims the voltage spike caused by jumping will damage light electronics. I don't think a 225 amp boost would do you any good any way, most diesels need a lot more amps than that to start it.
Jim
MarkB_MI
03-08-2008 03:54:39
As long as the battery is in reasonably good condition there should be no problem. Now if the battery is "open" or isn't connected properly, there could be a big voltage spike when you stop cranking. The easiest way to avoid this is just to look at the ammeter on the charger: if the battery isn't taking a charge when you hook up the charger, then you need to fix that problem before you try to crank the engine.
John T
03-07-2008 12:17:51
Im like my "old" friend I dont forsee any problems to that diesel, after all you have the big honkin (way more ampacity then that charger) electron bank of a battery sittin there to absorb n smooth things out, its merely replenshing some of the lost electron energy into that big battery bank n some into a non sensitive DC starter motor (if any left lol) HOWEVER Mike has a good point, on some modern cars with all their sensitive electronics n computers jumping has been known to cause problems
John T
Mike M
03-07-2008 10:59:27
Here at the car dealer there have been some instances of of things happening after a car was jumped. Of course no one will admit it and no way to prove it but I suspected someone hooked it up reverse polarity ? or maybe it was the surge ? this new fangled stuff is VERY sensitive.
ispud
03-07-2008 10:55:15
Used them for years.
circus
03-07-2008 10:32:04
Damage maybe to the booster but it's should be protected.
old
03-07-2008 07:35:04
As long as you hook it up + to + and - to - and its the same voltage as your battery is nope it will not cause any problems. Shoot the battery it self should be 700 plus CCA so all your doing is adding another 200-250 CCA to the system
