Tool Talk Discussion Forum
Syn Oil in GMC
Joe Pro
03-06-2008 15:39:22
Ok so I bought a GMC 4.3 a while ago and have maintance log from it. I am the 3rd owner the second owner put about 1000 miles on it, now I think the 1st owner changed it over to synthetic oil in '05, but I am not sure, nor am I sure fi the last owner continued the syn oil, So will it hurt anything if when I change it I just put in regular 5w-30??
lucas boy
03-07-2008 04:29:21
 Re: Syn Oil in GMC in reply to Joe Pro, 03-06-2008 15:39:22
wont hurt as others have said. i use syn in my engines that dont leak oil. i put some in my tiller once and noticed more power, them my zero turn mower with kohler motor and it had more power so i use it in my cars now too.its the best lubricant for engines. use it on my gun slides too. lucas
Chuck UR
03-07-2008 04:27:15
This just in -
http://www.hemmings.com/newsletter/newsletter.html?volume=3&issue=39&id=1564&refer=news&emlid=180357#1564
Nolan (foxtrapper)
03-07-2008 03:38:21
You can switch back and forth between synthetic and non-synthetic as often as you like. They are fully compatable with one another.
buickanddeere
03-06-2008 19:44:47
Very cold, very hot or continuous heavy loads. Use synthetic. General Motors ships some vehicles with synthetic in the crankcase, trans & diff from the factory. There must be a reason.
Mike M
03-07-2008 08:12:45
 Re: Syn Oil in GMC in reply to buickanddeere, 03-06-2008 19:44:47
Well here's the # 1 reason.
Gm's Versatrak fluid is $27.37 PER EACH 16.9 oz. bottle !!! and less we forget 16 oz. is only 1 pint.
buickanddeere
03-07-2008 08:44:00
 Re: Syn Oil in GMC in reply to Mike M, 03-07-2008 08:12:45
Purchase Amsoil instead of GM stuff. If parts start to rub and wear because mineral oil won't maintain lubrication and cooling. A true synthetic oil appears cheaper than rebuilding machinery.
dr sportster
03-06-2008 19:28:21
My dads buddy was babbling some nonsense about ruining the motor if the crankcase has residue of synthetic it it.Ive never heard that before.I dont research too many oil sites but Ive put mineral oil and synthetic and not had problems.Of of the best articles on oil ever was in SCIENTIFIC AMERICAN magazine but that was a long time ago and is outdated.Hey you could use that crankcase flush,i dont know about that but Ive tried it.I find synthetec and mineral to give the same service and prefer the cheaper oils.Except Harley oil and that I pay dearly for 60 weight at the dealer.Good luck with the new truck.GMC very good.
timcasbolt
03-06-2008 16:58:39
Bob's right. Use whatever you're comfortable with. There are some long term benefits to synthetic, especially if you rack up a lot of miles, but the gains are hard to justify in normal use.
Bob
03-06-2008 15:49:06
You are obsessing over NOTHING.
Use WHATEVER oil you want, so long as it meets the required SAE and viscosity specs.
toolman
03-06-2008 21:27:39
 Re: Syn Oil in GMC in reply to Bob, 03-06-2008 15:49:06
What Bob says and i might add, best thing for your truck as far as oils go is good maintaince , i.e. regular oil changes.
