Tool Talk Discussion Forum
Steel Tubing Working Pressure
Tom from Buckey
03-06-2008 07:46:38
I'm installing remote hydraulics on my MF 150 and need to know the working pressure of 3/8" steel tubing SAE Standard J527. I bought it at an auto parts store and concerened that it wont work well at 1800 psi (all that the pump will produce). I'm in a rural area and will have to find a hydraulic/hose shop.
I googled the web for SAE J527 and couldn't find the information I needed. Just a discription of the meterial used to produce the tubing.
Thanks, Tom
Tom from Buckeye Lake
03-08-2008 08:14:22
 Re: Steel Tubing Working Pressure in reply to Tom from Buckeye Lake, 03-06-2008 07:46:38
Sorry for the late come back. Electric has been out this morning.
Yes, the tubing is supplied with inverted flare and fittings. The wall thickness is around .030" using my dial calipers. I have flaring and bending tools.
Thanks for the replies.
Joe(TX)
03-07-2008 05:02:28
There is one critical peice of information needed and that is the wall thickness. J527 is double wall brake line. SAE J524, SAE J525,
SAE J526 and SAE J356 are steel hydraulic tubing.
3/8 tubing .028 wall will handle 2000psi.
Gun guru
03-06-2008 13:50:13
You have to give a wall thickness for me to give you an exact burst/working pressure. I have a Fluidpower engineering handbook in front of me. But I will say this: 1800 psi is low for 3/8" steel tubing. The book I have uses the Barlow formula on a graph.
greygoat
03-06-2008 08:32:06
ASTM hydraulic grade tubing...
(American Society of Testing Materials)
has the working pressure stamped, in ink, once
every foot or so, burst is usually 4 to 1.
Dick L
03-06-2008 08:23:34
If it will not take a bunch more that what your hydraulic pump would put out you sure do not want it used on a breaking system.
That being said I looked it up and you can read for yourself. All I could find was SAE J524 The burst tests should not be very different.
shawnspeed3
03-06-2008 08:17:56
Is the tubing the brake line tube that is pre-flared?????If so you should be good to go, most brake systems operate at around 900-1000 psi with spikes on some systems above 1200psi. The SAE site specifies that J527 has a 4:1 safety margin...that is that burst pressure is 4 times nominal working pressure....well within your 1800psi operating pressure given a 1000psi nominal operating pressure for the tube,would get you a 4000 psi burst...or better( the working pressure charts on the website wouldn't load)Good luck Shawn
