Tool Talk Discussion Forum
Need part fot THOR Bench Grinder
Ted in NE
03-06-2008 06:04:35
Have a THOR 1/2 HP bench grinder. Need a rotary switch, any ideas where to look?
Thank you, Ted
Bret4207
03-08-2008 06:56:22
 Re: Need part fot THOR Bench Grinder in reply to Ted in NE, 03-06-2008 06:04:35
Thor! I haven't seen that brand in decades. Used to be good stuff IIRC. Get to a REAL electric motor shop and they'll fix you up. Might as well have it cleaned and serviced while it's there. $20.00 and it'll go another 40 years.
Bob
03-06-2008 18:03:08
Go to an electric motor shop and get a generic "solid-state starting switch", and wire it in, in place of the centrifugal starting switch. Does the same thing, with no moving parts or contacts. (They are sold by the approximate HP rating of the motor.)
JerryCPP(WA)
03-06-2008 11:03:47
Look in your yellow pages for an Industrial Electric repair shop. They will fix you up in no time.
cactus farmer
03-06-2008 09:20:38
I've never worked on a rhor but have done a few others.Take the old one out and see it it's got an amp or horespower rating. Go to any well stocked hardware store and find one that will fit both amp/hp wise and in the hole the old one came out of. If you can get a rating higher than you need it''s a plus,start up on these motors draws a lot of current and toasts switches if their not heavy duty.
Dusty MI
03-06-2008 08:59:36
If your talking about the internal switch that turns off the start winding, try Grainger.
Pollack Pete
03-06-2008 08:43:34
I hate to answer a question with a question,but..... .why does it have to be a rotary switch??? Why not just a simple toggle switch?? How many wires on your present switch??
Ted in NE
03-06-2008 16:07:47
 Re: Need part fot THOR Bench Grinder in reply to Pollack Pete, 03-06-2008 08:43:34
Thank you Dusty, It is the internal switch for the starting winding. Will try Grainger. The grinder is old but very serviceable otherwise.
