Tool Talk Discussion Forum
What determines a welder's OCV?
Stan in Oly, WA
03-05-2008 08:52:02
I often advise people on this forum to avoid cheap, off-brand stick welders because they are so hard to make work well. One thing that makes a welder especially hard to use is low Open Circuit Voltage. I've read that 90 volts is either the optimum OCV, or the highest normally offered, or the top physical limit---I don't remember which. When I started paying attention to this figure, I noticed that Lincoln buzz boxes and Hobart Stickmates have 80 volts OCV, a Century welder I used to own had 72, and a Chicago Electric 80 amp inverter welder has only 37.5, which makes it better at producing frustration and curses than at producing decent welds. I suspect that a Craftsman AC stick welder I once owned must have also had very low OCV because it was always hard to get going and keep going.
What determines a welder's OCV? Is it a characteristic of the transformer or does it depend on the electronics the manufacturer builds into the welder's circuitry? Is it expensive to build a stick welder with high OCV? It seems like it must be or why would any manufacturer bother to produce welders that were hard to use and didn't work well? After all, word gets around.
Stan
T_Bone
03-06-2008 23:13:11
 Re: What determines a welder's OCV? in reply to Stan in Oly, WA, 03-05-2008 08:52:02
Hi Stan,
I see where your idea to select a machine on OCV might be a benefit on spec's on high end machines but one would still have to revert back to the first important basics of duty cycle and amperage as a place to start when comparring spec's of different machines.
The reason I say this, is on most CC machines most designs are based on 80/OCV and most CV machines are designed on 45/OCV from what I can find in my text refferences. That may very well be outdated info on the inverter based designs.
To me it still boils down too finding a machine with the correct duty cycle for the amount of amps I want to run. Then it's off to the Vo-Tech schools to try the lastest and greatest machines as most Vo-Techs run machines that are not very old, less than 3yrs old, or the machine technology hasn't changed.
Back when, we would send a couple experienced weldors to the welding supply shop to try out the machines before we bought them. I've asked about that at my local supply shops and they told me they don't do that any more.
As to the machines starting ability, I haven't used any of the machines less than a $1000 that has a hard starting arc. That's probably due to my technique of using approx 150a on 1/8" electrodes depending on the metal thickness. I just don't see a problem from here.
The Miller Thunderbolt 200aAC/150aDC, about $425, that I bought my son 4yrs ago had a weld puddle that closely matched a AC molten puddle while on DCEP using 7018. I contribute that to the cheap transformer design with little external arc stability componets found in high end machines. I'm not saying it wasn't a adequate arc for the price of the machines today but it sure wasn't even close to the old Lincoln 225a AC arc of 50yrs past.
For machines under $500, a person is just not going to find a machine with more than a 20% duty cycle at around 150a, so to me OCV would be a mute spec point on the cheaper machines and not much more useful on the high end machines as OCV is taken from terminals at the machine and not at the point of use.
T_Bone
Stan in Oly, WA
03-08-2008 08:59:28
 Re: What determines a welder's OCV? in reply to T_Bone, 03-06-2008 23:13:11
Hi T_Bone,
It's almost totally a matter of curiosity for me now---something I'd like to understand better, but with no specific application in mind at this time. Basic information has a way of being useful to you unexpectedly, though. Learn enough of the basics about a complex system and it will sometimes start to make sense in a way that will allow you to deal with it more usefully.
What I've learned about OCV just from this thread has made me see that, taken alone, it's not going to provide the simple benchmark of arc starting capabiblity in low end machines that I hoped it would.
I thought you might be interested in what the experts at Lincoln Electric had to say about OCV when I asked the same question there:
"Good Morning Stan,
It is a design characteristic determined by the engineers when the manufacture the machine."
That's it, in its entirety. Of course, it was free.
All the best, Stan
Fred Martin
03-06-2008 11:33:00
This is not an answer to your question but, haven't I seen when I had the cover off of one of my welders...there is a metal capacitor that gives the arc a little extra zip when starting the arc. Also, how is the arc voltage measured? Just by putting a voltmeter across the leads?
Stan in Oly, WA
03-06-2008 14:38:55
 Re: What determines a welder's OCV? in reply to Fred Martin, 03-06-2008 11:33:00
Hi Fred,
I know that you can measure the OCV by putting your voltmeter across the leads, because I've done that. I'm not sure whether you can measure the working voltage across the leads while welding, but I'll try that tonight and let you know.
BTW, I've been meaning to ask you, are you the same Fred who used to use Fred OH as your handle, and sign off with "L8R, Fred"? I liked that Fred, too.
All the best, Stan
HF
03-06-2008 16:58:25
 Re: What determines a welder's OCV? in reply to Stan in Oly, WA, 03-06-2008 14:38:55
Put a meter on the leads before welding and leave it on when you start welding. That's how some really strict procedures are done. Machines with meters effectively do the same thing but because of losses due to cable lenghts or bad connections etc., the readings at the machine can be off.
36 coupe
03-06-2008 02:04:12
For safety welders are limited to 80 open circuit volts.Some rods start harder than others.7014 starts easy.7018 wont start on small welders.I have an old welder that has a low an high voltage tap.My DC converter starts real easy.It has 90v oc.
KEB1
03-05-2008 19:10:36
The open circuit voltage of a transformer is determined by two things, the ratio of primary turns to secondary turns and the characteristics of the core. The loaded voltage of a transformer is determined by the first two characteristics plus the resistance of the secondary winding.
The typical power supply type transformer has a core size and materials such that the core never saturates, i.e. never reaches the limit of its ability to be magnetized during each half cycle of the AC input. In this case, the open circuit voltage is determined solely by the ratio of the windings, and the loaded output voltage is the open circuit voltage minus the voltage drop due to the output current flowing through the resistance of the secondary windings.
However, if the core is designed to modify the way it is magnetized during each half cycle, then the transformer can produce an almost constant output current, and will vary the output voltage to force this current through whatever load is applied, up to the maximum voltage as determined by the primary/secondary windings ratio. This is the typical approach to an AC buzzbox welder. By selecting the turns ratio to produce a high open circuit voltage, and then depending on the core characteristics to regulate the current, I can make the welder easy to start.
Now, in order to save money, the manufacturer would want to build the transformer with the least number of secondary turns and the smallest possible wire size. By reducing the number of secondary turns to the minimum that can produce enough voltage to sustain an arc, the manufacturer reduces the amount of material required and the cost of manufacturing the transformer, without having to give up any of the rated output current.
However, by reducing the number of turns, the manufacturer does reduce the maximum open circuit voltage, which is determined by the primary/secondary turns ratio. This results in the lowest cost for a given welding current, but makes starting the arc difficult.
Switching mode (inverter) supplies also use a transformer, but run it at frequencies in the 10's to 100's of kiloHertz, rather than at the 60 Hz power line rate. The high frequency input is generated by rectifying the 60 Hz input and then using an electronic switch to "chop" the DC into the high frequency pulses applied to the transformer. The output voltage is regulated by controlling the duty cycle of the chopper, which in turn controls the average current into the transformer.
If I were designing a welder based on inverter technology, I would include an active voltage regulator that would raise the voltage to start the arc, and then lower it to whatever is needed to maintain the desired current. I've never looked at the circuit for one, but I'd suspect that the cheapo Chicago Electric on probably omitted the active voltage regulation and simply controls the chopper to a single voltage, hence the low open circuit voltage.
Keith
Stan in Oly, WA
03-06-2008 14:25:17
 Re: What determines a welder's OCV? in reply to KEB1, 03-05-2008 19:10:36
Thanks for the great answer, Keith. When I've had time to mull it over a little, I may ask you for some clarification on a point or two I'm not totally clear on, if you don't mind.
Stan
HF
03-05-2008 22:00:41
Very good explanation. I used a small compact expensive inverter (130 amp) and it had a knob for adjusting the hot start feature that gave you more amps just for a second when striking an arc. Maybe it just raised the voltage and not the amperage?
Confusing?
03-05-2008 10:36:08
I think it also depends a lot on the type of machine you're using. A top of the line Miller XMT 304 inverter only has 60 OCV, I think, and starts welding as soon as you get the rod close enough. I've heard that 90 OCV is the maximum for safety reasons and is a NEMA requirement. Inverters have a much higher HZ. rating so maybe that's why they don't need as much OCV? OCV is also lower when TIG welding on some machines.
guido
03-05-2008 10:31:48
Hello Stan.
From What I understand about open voltage is that it makes the stricking of the initial arc a bit easyer.Old buzz boxes as you mentioned were a bit hard to get started. Some welders, like the one I used at work, have a switch that has 2 positions for starting voltage. One position is marked start, and the other is continuos. I used the starting position for low hydrogen rod.The swich by the way is marked high frequency. On the continuos position it provide high frequency for aluminunm welding. This position may be used for other procedures, that I don't know. Also it is very important, as you know, that the welder provide a stable ON voltage and a good duty cycle, if you are going to use it for critical work, and a long period of time. Guido.
HF
03-05-2008 10:43:40
 Re: What determines a welder's OCV? in reply to guido, 03-05-2008 10:31:48
Any machine that has High Frequency for TIG welding built in shouldn't need it for stick welding. HF isn't built into a low end machine. HF is normally used for starting a TIG arc on Steel or SS and used continuosly on Aluminum. At least on a conventional machine anyway.
guido
03-05-2008 12:18:47
 Re: What determines a welder's OCV? in reply to HF, 03-05-2008 10:43:40
Hello HF
You are right, but with the high frequency set for start it is much easier to get an arc started. Some specialty electrodes covering sometime cover the welding material. When that happens you have to hit the work hard to expose the welding material, and then you can get the arc started. Guido.
HF
03-05-2008 14:44:44
 Re: What determines a welder's OCV? in reply to guido, 03-05-2008 12:18:47
It would work for 7018 and other low hydrogen rods but you could tap the rod on something else solid to knock the slag off the end.
IH2444
03-05-2008 09:42:53
Depends Stan. If it is an old transformer type of stick welder, the transformer determines the OCV.
If it is a newer one without transformer, the electronics determines the OCV.
As far as the best OCV I think it sort of depends on what you are trying to do with the wleder, ie rod size, etc and how well the voltage holds up after you strike the arc, but I will leave that to the more expert like Tbone and such.
