Tool Talk Discussion Forum
Wheel balancer
Slowpoke
03-03-2008 10:38:12
Can the old style "on the car" wheel balancer be used on the drive wheels? I only remember it being used on the front of rear drive cars. Check out the one on eBay: 110228160528. I have a couple of the balance rings that I picked up somewhere in hopes of finding the rest of the machine.
Ron in Nebr
03-04-2008 23:03:12
 Re: Wheel balancer in reply to Slowpoke, 03-03-2008 10:38:12
Assuming it's a normal passenger car or light truck with the same tires and wheels front and back, you could just do your fronts, then swap the rear(driven) tires to the front and balance them. Opposite for a front wheel drive of course. This won't help if you have something like an out of balance brake drum, but will at least get the wheels and tires balanced.
As for disc brakes, they are designed to have a constant slight drag. You could remove the tires first and pry the caliper a little bit to compress the piston(s) before balancing, and it wouldn't be a problem as long as nobody got in the car and touched the brake pedal till you were done. For that matter, it's only a couple bolts to remove the calipers completely....
dave guest
03-03-2008 17:47:03
Slowpoke, somebody told me you couldn't use your wheel spinner on disc brakes. Drive wheels, got no idea. Like others said you don't need it on drive wheels. But what if you got posi, story goes vehicle will run away. Always meant to try that but never did.
Slowpoke
03-03-2008 23:16:45
 Re: Wheel balancer in reply to dave guest, 03-03-2008 17:47:03
I just had it used once on my IHC '65 Travelall which had positraction rear, but I think only the front was balanced because of vibration while driving.
dave guest
03-03-2008 17:46:53
Crem
03-03-2008 14:32:05
That is interesting as I have the drive part but do not have any balance wheels. I don't know what brand mine is but it doesn't look like the one on eBay and mine is an orange color. I have used a couple of times on my older cars to run the wheel up to speed and then feel on the fender to see if it was vibrating.
Jerry Coulter
03-03-2008 14:05:00
I was able to use my Hunter on-car balancer on my 82 Buick, both front and rear. But I can't use it on my newer front wheel drive car because the wheel is dished so deeply it interferes with the balancer head. My Stewart Warner-Alemite balancer with the strobe light works on anything. I usually take off the front wheels and balance them on my Bear balancer so I can take out any vibration with both a dynamic and static balance. When balancing a drive wheel on car, just remember that when the speedometer says 30 MPH, the wheel is really going 60 which is close to the optimum working speed.
bill mart
03-04-2008 15:18:10
 Re: Wheel balancer in reply to Jerry Coulter, 03-03-2008 14:05:00
why would the wheel be going 60 if the speedometer is showing 30?
Ron in Nebr
03-04-2008 22:57:35
 Re: Wheel balancer in reply to bill mart, 03-04-2008 15:18:10
Kind of a long explanation, but here goes:
If one drive wheel is blocked and the other is being spun, the driveshaft will only be spinning at half speed due to the action of the gears inside the differential, thus making the speedometer read half of what the wheel's turning.
Try it sometime- jack the rear of a rear wheel drive non-positraction vehicle up(use proper jackstands). Put a mark on the tires and one on the driveshaft. Turn the driveshaft by hand and note how many revolutions it takes for the tires to make a complete revolution(make sure both tires are turning the same). For, say, a 3.00:1 gear ratio, the driveshaft will turn 3 times for the tires to make one complete revolution.
Now, hold one tire from turning(note- this wont work with a positraction differential) and do the same thing. With one wheel stopped the driveshaft will only have to be turned 1.5 times for a complete revolution of the one rotating wheel.
Wild Bill
03-03-2008 12:16:15
you don't need it on the drive wheels. Raise the rear of the vehicle (if rear wheel drive) block the wheel you arent balancing (we would let it down on a rim, w/o a tire on it) and clamp your ring on the free tire. Start her up and balance away.
BE CAREFUL though, it is a very dangerous thing to do. Unbalanced tires can explode at high speed, and you could easily get wrapped up like a prezel on that spinning tire
bradk
03-03-2008 10:46:46
At the old service station,we used the drive wheels to propel the balancer.Only used the electric motor for non drive wheels. ~brad
