Tool Talk Discussion Forum
cutting torch vs plasma
Dell (WA)
03-02-2008 00:05:41
Guys..... ..I need to cut a 1 x 4 hole in 1/4" steel plate and don't really wanna hacksaw it. Since I don't have a oxy-acetylene cutting torch I'm gonna haffta PAY for someone to do the cutting. The last acetylene cutting I had done, was very ROUGH and took much file and grinding to make acceptable. Trying to gitta handle on the COST of acetylene vs PLASMA cutting. Enny ideas???..... .TIA, Dell
dieselpup
03-03-2008 12:50:08
 Re: cutting torch vs plasma in reply to Dell (WA), 03-02-2008 00:05:41
I"ve gotten along very well using cutting wheels on my angle grinder. Haven"t spent the cash to get a torch set yet since brother-in-law has one across the road. The wheels could get expensive if you are doing a lot of cutting but they are way faster than a hacksaw. I ran a cnc plasma cutter for a year or so and it would do a great job up to about 1" steel. Anything thicker than that we would have flame cut. 1/4" should be no problem for either process, you would be mostly paying for setup time.
Dell (WA)
03-03-2008 00:16:56
Guys..... ...thanks for all the ideas and comments. Its a 1x4 INCH hole thru a 5x20" U-channel 3-in from open edge and centered lengthwize. Channel is semi-rusty and may end-up in a electo-derusto bath along with some very rusty BIG acme-thread screw adjusters. It also has a 2in crack that I need to stop-drill and "V" for welding.
I haddn't thought about "jig/saber sawing". Could be an alternative as I have both and room to operate...er...saw? But drillin' abunncha holes and hacksawing was my first idea and you guys did me better..... ...tnx, Dell
jose bagge
03-02-2008 11:23:49
1st: with 1/4" i'd probably just whip out a sawzall or whiz wheel ( or a hole saw if round) and have a clean, clean hole. BUT...
plasma vs torch. I have both, and always seem to grab the torch. For a clean cut, I have a big peice of bar stock (1" thick, 3" wide, 20" long) that I use as a guide, and I hold it to the inside edge of whatever I'm cutting and pull along it as a straight edge. It must also work as a heat sink, because it always leaves a nice clean edge. You can pull a really straight line with a torch if you have a guide. Plasma is fine, but the material needs to be clean and can not be rusty- which eliminates most of the stuff I'm cutting! With the right tip, I've cut speaker holes in the rear window tray of cars with a torch...blown lugs off without damaging alloy wheels...It's my "go to" tool!
mjbrown
03-02-2008 09:28:42
If this is a 1X4 INCH hole you'd have it done by now with a hack saw and oil. If 1X4 FEET, a plasma cutter is the way to go if you can find someone with one. You can make a plywood guide for the cutter.
Bob Huntress
03-02-2008 08:06:20
A Menninite friend of mine uses the core from flashlight batteries and an arc welder to cut holes in steel.
504-2
03-02-2008 06:46:51
Dell, Around here it is 50.00 for a metal shop minimum, but a lot of small shops will do it for 10.00. Plasma is quicker and cleaner than a torch. It seems every shop around any more has a plasma cutter, ask around at the local coffee shop,maybe somebody will offer to do it for a cup! LOL
circus
03-02-2008 04:11:12
If this is a once a year need just drill two 1" holes and jigsaw between. A carbide burr in a $10 die grinder cleans it up in a jiffy.
Crem
03-02-2008 07:28:00
 Re: cutting torch vs plasma in reply to circus, 03-02-2008 04:11:12
Circus, I think that I would go with your method and if it is a rectangular hole, drill a hole in each corner and use a sabre saw. It may take a blade or two and a little effort but the time and gas used to find someone to do it is also a consideration. If the going gets too hard it can always be taken to someone.
Bob
03-02-2008 03:56:53
I have a simple (and out of date) Century 60 Amp plasma cutter, and it could cut the hole you need with very little heat distortion, and pretty nice edges in probably less than a minute.
It wold be "child's play" for a pro to do it with even better equipment.
I would either clamp a straight edge to the work, and move it 4 times, or make a wooden pattern of the rectangular box, 1/2" larger in each direction, to allow for the offset between the cutting guide and the center of the tip.
Either way, nothing to it, QUICK, and nice results.
MarkB_MI
03-02-2008 03:47:48
Dell,
EVERYBODY who does any kind of wrenching should own an acetylene torch. Once you have it, you'll wonder how you ever got by without it. Not only for cutting, but brazing, welding and (most importantly) heating up stuff that won't come apart.
There a torch that's been out for many years called the Henrob. It will cut steel just as clean as a plasma cutter. The main reason flame-cut steel is rough is that the preheat orifices re-heat the steel after it's been cut. The Henrob is directional: the preheat orifice is ahead of the O2 orifice.
benny2
03-02-2008 01:10:28
 If cutting steel Re: cutting torch vs plasma in reply to Dell (WA), 03-02-2008 00:05:41
If cutting steel with OX/AC the torch tip is clean and set right the operator knows whats going on the burn should be nearly as clean as a machine cut.
Rusty, painted or dirty metal cuts bad though. But even then a good operator can do a decent job. If you are looking for a machined like surface that can only be done on a milling machine. Find a machine shop. Or finished with a file. The problem there, is that OX/AC hardens the metal by inducing carbon into the burn. Effectively case hardening the material!
Bob Huntress
03-02-2008 00:13:28
If all you're doing with the torch is cutting, I use propane to cut the cost, as well as the steel.
