Tool Talk Discussion Forum
Tire studs
jack12345
02-29-2008 20:20:20
Is there a way to remove tire studs once they have been installed? I have some traction tires that I would prefer to be stud-less. Thanks,Jack
jack12345
03-01-2008 20:51:52
 Re: Tire studs in reply to jack12345, 02-29-2008 20:20:20
Thanks for the info, removed studs from two Goodyears this afternoon. Found a 1/4" drive 3/16 socket on a nut-driver fits right over the barrel of the studs.They pop right out once you get the hang of it.
El Toro
03-02-2008 16:28:03
 Re: Tire studs in reply to jack12345, 03-01-2008 20:51:52
third party image
Here's that Mercury Bobcat. It had a V6 engine and my wife didn't like since it would make the tires squeal. When I sold it I had a teen to look at it and he took for a drive and it squeal a little. I told the wife he would buy it. Came back and bought it, I already had it state inspected. The state gets a lot of revenue just from these inspections. It runs about $100.00
a car just for the inspection. Any repairs are extra. I usually have everything fixed before I take them in. Hal
El Toro
03-02-2008 16:12:53
They outlawed those studded tires around here in 1970's. The Post Ofice trucks still have them.
I had them on a big Mercury that I studded the tires myself. It was sure good on ice. Hal
PS: I bought a Mercury Bobcat used from WV and it had studded tires and I had to remove the studs to get it thru state inspection. I used a pair of diagonals to pull them out.
MPK
03-01-2008 19:46:02
We used to use them here in Mn but now they are outlawed here because they are too hard on the roads. After just one winter of use we could see how they were wearing the roads in the tracks.
Aaron Ford
03-01-2008 07:06:18
Get a set of dykes (new studs) or a small reg head screwdriver (worn studs). They pop right out.
My parents car is driven all year with snow tires. The front tires are installed with studs and come March or April, they are pulled. The tires are replaced the following fall with fresh studded tires. The car gets about 35-50K a year so the front tires are shot. The rears last several years.
HTH
Aaron
Stan in Oly, WA
02-29-2008 22:18:44
Hi Jack,
I've copied and pasted this information from an online retail tire site called The Tire Rack.
All the best, Stan
"Can studs be removed from snow tires and still be safely driven?
If the tires are relatively new, with significant remaining tread depth (more than 7/32-inch), removing the studs will probably be worth the effort. It can be accomplished by lubricating the studs (best to make use of the same tire lube used to mount tires, since other lubricants may actually harm the rubber) on an inflated tire, grabbing the top of each stud with a pair of pliers, and twisting as you pull the stud out.
If the tires are older, with less remaining tread depth (less than 6/32-inch), the studs can still be removed in the manner described above but the reduced tread depth will have already significantly reduced the tires' ability to bite into snow to provide good winter traction.
Once the studs have been removed, the tires should be submerged in a water tank (as done with tires to locate punctures) or have its tread area sprayed with a window cleaner to confirm the absence of bubbles (the presence of continuing bubbles would indicate that the removal process punctured the tire and was allowing air to escape). The tire should be rinsed with water and installed on the vehicle after setting the tire inflation to the pressure indicated on the vehicle placard.
While the tire can be used if no bubbles are seen, its air pressure should be checked daily for a few days and once a week for the first month to assure that there are no slow leaks."
