Tool Talk Discussion Forum
Welding Experts - Help
TomTex
02-29-2008 14:11:11
There is something I dont understand about MIG. I am using an older (early 1990s) Lincoln Electric IdelaArc SP-150, 230 volt, with 33 lb roll of .035 solid wire. All the settings such as power, wire feed speed, seam, stitch, spot, burn back, are explained very well in manual. The power setting is from 0 to 10 and is stated in "Volts" such as 21 volts, 28 volts, etc for different metal thicknesses. The machine has a voltmeter on it that registers the volts when you hit the trigger. Most of the time folks talk about "amps", but there is no amp measurement on this machine, just volts. But when I use my Miller Bobcat 225 stick welder everything is measured in amps. I know some of you can straighten me out. Thanks, Tom
TomTex
03-01-2008 06:40:32
 Re: Welding Experts - Help in reply to TomTex, 02-29-2008 14:11:11
Thanks to all. I better understand the process now. I have always welded stick since high school shop classes. My neighbor son, an ag teacher picked up a wire welder from the school shop for 50 bucks! Its the IdealArc i am using. He had no manuals, no instructions, etc. I have cleaned up the machine, ordered Operator manual, parts manual, cleaned and adjusted everything, ordered new knob, and some other parts, to get the thing in shape. He is letting me use it for 2 or 3 months for getting it in shape. Again thanks a bunch. I will post another question above. Tom
RossIL
03-01-2008 08:14:10
 Re: Welding Experts - Help in reply to TomTex, 03-01-2008 06:40:32
Go to Lincoln Electric's website. They have manuals you can download and print off. I've got one for my SP 170T that way.
Ross
TomTex
03-01-2008 08:59:38
 Re: Welding Experts - Help in reply to RossIL, 03-01-2008 08:14:10
Thanks Ross, that is what i already did. I said "ordered" in error. I actually downloaded both the Operator manual and the Parts manual from Lincoln, in pdf format. Printed and put in notebook. Tom
MarkB_MI
03-01-2008 04:36:04
As others said, with wire feed welders, speed=amps. Crank the speed up so you get good fusion without burn-through. You need to use enough voltage to keep the arc going but not so much that you get a lot of spatter.
Fawteen
03-01-2008 03:47:33
It may help to understand that the final product of either CV or CC is power (Watts)aka heat. P=IxE.
If you hold voltage at a fixed value (CV) and vary the amperage, power in watts varies directly with the amperage (more amps, more power).
By the same token, if you hold amperage at a fixed value (CC) and vary the voltage, the same thing happens, (more volts, more power)
Clear as mud?
KEB1
02-29-2008 18:33:27
Let me see if I can clarify things a little. MIG is a constant voltage process, i.e., the welder generates a constant voltage which you set with the voltage control, and the current through the arc is controlled by other factors such as wire speed and stickout. The right combination of the fixed voltage and variable current produces an appropriate amount of heat and an appropriate deposition of filler.
Stick welding is a constant current process. The welder controls the amount of current which flows through the rod, based on where you set the controls, and the voltage across the arc is a function of factors such as arc length. In this case, the right combination of a fixed current, rod size, arc length, etc., combine to generate an appropriate amount of heat & melt the rod at an appropriate rate.
Haven't looked at the physics of why one process works better with the voltage held constant and another works better with the current held constant, but that's the way it is.
Keith
Stan in Oly, WA
02-29-2008 17:34:11
Hi Tom,
Aren't you glad you asked?
Stan
MIG help
02-29-2008 17:21:52
Voltage and wire feed speed are more commonly used terms for MIG welding. Sometimes Volts and Amps are listed as well as wire feed speed. It depends on the machine. Some may have Volt and wire speed gauges and others might have Volt and Amp gauges. I.E./ Lincoln vs. Miller. It would be common on a procedure qualification to list all three. Stick welding starts with high volts around 80 and once an arc is struck, the volts go down to approx. 24. In MIG the volts stay the same. It's called slope. The Volt/Amp curve. Stick has a high volt/Amp curve and slope. MIG has a relatively flat Volt/Amp curve and slope usually, but for certain metals like stainless steel a higher slope on a MIG machine is desirable for doing the welding. High end or machines made especially for other metals will have slope control. It is not the same as Inductance control. Volts does not control Amps on a MIG machine. Wire speed controls Amps. Usually more wire speed needs more volts. Volts plays an important role in what type of wire and what type of metal transfer you need for that wire and the welding parameters you want to use. In welding Amps is considered the push and Volts is the flow. Thus more wire feed speed equals more push and more amps. Hope this clears it up for you.
Ryan - WI
02-29-2008 16:36:59
Tom, When you are talking about welders there is always an abreviation used. That abbreviation is CC or CV. CC stands for constant current, meaning the voltage changes while the amperage stays the same. Your MIG welder is this type. CV stands for constant volrage, meaning the voltage remains the same and the amperage (current) is changed. This is used in SMAW (stick) and TIG welding. Different types of electrical patterns for different types of welding.
T_Bone
02-29-2008 14:49:08
Hi Tom,
Volts are amps when it comes to Mig. As the voltage increases so do the amps available but then there's wire distance or arc length to consider that plays even a larger roll in Mig welding that will also vary the applied amperage.
If you want nice welds requardless of the process used, learn to control your arc length.
T_Bone
Fough
02-29-2008 14:42:28
One machine is maintains a constant current while welding. The stick welder
And the other maintains a constant voltage. The MIG welder.
Once the mig is set to a particular voltage, the amperage will increase as you increase feed speed.
