Tool Talk Discussion Forum
Refacing rocker arms - how is this done?
Kevin LA-CA
02-29-2008 09:12:12
I am trying to collect tools to rebuild old engines. Several of the engines I have will need - 1930-55 tractors will need this.
I understand that valve refacers (grinders) can do this, but what does the tooling look like?
What other precautions should I observe?
thanks
kevin
Kevin LA-CA
03-01-2008 10:42:50
 Re: Refacing rocker arms - how is this done? in reply to Kevin LA-CA, 02-29-2008 09:12:12
Thanks for the reply. I found the tooling to grind the rockers - I suspected that is what it was.
However, this mount is for a different model grinder (different color) & I am not sure how or if it can be mounted properly. Anyone have a photo of their's installed?
thanks
kevin
jdemaris
02-29-2008 10:25:22
Both my Sioux machines have the rocker-grinder attachment.
Mike M
02-29-2008 09:41:58
I have one with my old Black and Decker valve refacer machine. This machine has 2 stones. One you use for the valve face and on the other end of the machine there is one you can do the ends of the valve stems then pull out the vee block attch. for the stems and insert the rocker attch. which is an arm with an adjustable slide the has a pin with 2 cones that thread into each other. You stick these cones on each side of the rocker arm where the shaft goes,thread them together which holds them tight and centers them,then this sets over a pin and then you just start grinding. Start at one side and as you go tilt the lever out and rock the rocker so it matches the curve of the face. Kinda hard to write it all down. Hope it made some sense.
