Tool Talk Discussion Forum
Poulan 2150 Chain Saw
Katman
02-28-2008 02:46:08
Have to start this unit with the throttle wide open. The unit has plenty of power but will not idle. Has anyone had this problem and if so what did you do to correct it.
IH2444
02-28-2008 04:40:27
 Re: Poulan 2150 Chain Saw in reply to Katman, 02-28-2008 02:46:08
Clean the muffler ? Clean/rebuild the carb ?
I have a 2150 someone gave me. It had the same problems. I cleaned the muffler out and put a kit in the carb and all was fine. Not sure which one fid it but I suspect it was the carb kit, the little rubber parts get hard and do not work so well.
Check the fuel line while you are in there too for cracks/hardness.
Katman
02-28-2008 11:37:54
 Re: Poulan 2150 Chain Saw in reply to IH2444, 02-28-2008 04:40:27
IH2444
Will do and post back with the results. Thanks for the Quick response
Katman
03-01-2008 17:15:07
 Re: Poulan 2150 Chain Saw in reply to Katman, 02-28-2008 11:37:54
2/28/2008.....
Took muffler apart and cleaned real good ...
Re-assembled started 2150 and right now idling like a champ. Thanks for the help.
Katman
