Tool Talk Discussion Forum
Snow blade
Skybow
02-27-2008 17:06:32
I have a blade off of an old 3pt set up. It is 6 feet long. I have 1000' of driveway to keep free of snow. I was wondering if It I could buy another blade at auction or from some scrap dealer and weld them together to make a 12 foot long blade. I can weld it together and brace it with some extra iron I have. I would like to fix it so I can quick attach it to my Allied 595 loader in place of the bucket. Do you guys think this will work? What am I missing??? Thanks
jhill52
02-28-2008 05:00:18
 Re: Snow blade in reply to Skybow, 02-27-2008 17:06:32
12 ft is too wide for driveways. Find an 8 ft truck plow and adapt to your loader. You'll be happier and you'll be supprised how fast you can move snow.
Jerry
Goose
02-27-2008 19:42:36
I have a professionally built 8' vee plow that replaces the bucket on the loader on my H by just pulling three pins.
It's all the load the H wants, even with tire chains, particularly if the snow is a bit heavy. I'm not sure what would push a 12' angled blade.
I hardly ever use the H, though. I have an old Chevy 4X4 pickup with a 7 1/2' plow on it. Sitting in a warm cab sure beats sitting on a tractor. Plus it's a heck of a lot faster.
old
02-27-2008 19:23:49
third party image
Why not do it like this and then you have the best of 2 worlds. By having it this way its easy to steer and you can clean up just wide enough for what you need. This one is 8.5 foot wide and mounts to the bucket so no need to remove the bucket to use it. Takes about 15 minutes to hook it up or take it off
RobMD
02-27-2008 19:17:50
12 foot is way too wide for a blade that will be only a foot and a half tall. you'll be having snow pile up and over the blade. It'd take a heavy 4x4 tractor to do that, maybe 100+ horsepower size.
circus
02-27-2008 17:41:20
Not 12' but 8' 4x4s along the bottom and top of the blade with sheet metal between them would probably work. How would you tilt and angle the blade so it would be flat and the snow would move to the side? Is the loader strong enough if one end hits hard at speed?
Harvey3
02-27-2008 17:22:34
What are you going to push this with ? Truck or Tractor, 12 feet is alot of blade, that would be alot of weight with snow. You have to be able to maneover (sp) that rig around and 12 feet, is IMHO, way tooo looong.
Harvey
