New rod bolts
Wondering
08-18-2001 17:55:19
I was wondering if I should get new rod bolts when replacing bearings in my caravan engine(105,000miles) Its a 2.6 Mitusbitsu. I don't believe they have been touched befor. Wondering
Thanks Everyone
08-21-2001 05:45:17
 Re: New rod bolts in reply to Wondering, 08-18-2001 17:55:19
Thanks for the thoughtful answers. Wondering
Jerry B
08-20-2001 08:43:40
No need to replace the rod bolts on a "street" or regular duty engine. I have a Mitsubishi in my Plymouth I over hauled 50,000 miles ago. It has almost 200,000 miles on and going strong.
Even the head bolts are not "torque to yeild" type so no need to replace them either.
Dean
08-19-2001 09:49:55
Be careful! Some "modern" engines use "stretch to yield" rod bolts. The can never be re-used. Check your service manual or with the service department at your dealer.
John ne.
08-19-2001 08:29:41
Whenever we would rebuild a connecting rod we would put in new bolts. That is a very low stress engine, meaning they're unlikely to be stretched. First I would see what a set would cost. If the cost isn't prohibitive go ahead, it'll give you peace of mind. John in Nebr.
ferg
08-19-2001 08:50:08
 Re: Re: New rod bolts in reply to John ne., 08-19-2001 08:29:41
I've always re-used my rod bolts....and never had any problems...if they balanced your engine (by grinding the edges of the connecting rods) be sure to make sure that check the weights on replacement rod bolts if you decide to go that route.
As I recall, rod bolt torque is generally under 40 ft/#s so stretch shouldn't be a big problem.
ferg
