Tool Talk Discussion Forum
Hydraulic Brake Pressure
Glenn F.
02-27-2008 06:09:09
How many pounds of pressure will the hydraulic brake system on a '93 Bonnieville (rear brakes) be on a hard stop?
Thanks,
Glenn
Mike M
02-27-2008 08:10:43
 Re: Hydraulic Brake Pressure in reply to Glenn F., 02-27-2008 06:09:09
I borrowed some gauges from a service shop that you hook into your bleeder screw holes and checked my 1996 Dodge truck on the frt. once. I'm thinking you can get 1000 to 1500 ? psi if the engines running so your booster is working.
circus
02-27-2008 07:45:55
Lets figure it out. I don't know the specs. but say you step down on the pedal with 150 lbs.. Say your master cyl. piston moves 1" for every 4" of the pedal = 600 lb.. Say your master cyl. piston is 3/4" diameter which is .44 sq. inch = 1364 lb. per sq. inch.
