Tool Talk Discussion Forum
Oil for Pressure Washer Pump Crancase
PaulW_NJ
02-26-2008 11:37:51
I have an ancient Advance 600 electric pressure washer I"m trying to bring back to life. Does anyone know the weight of oil that should be used in the crankcase of a pressure washer?
Leland
02-27-2008 23:02:12
 Re: Oil for Pressure Washer Pump Crancase in reply to PaulW_NJ, 02-26-2008 11:37:51
or you can go to sites like www.windtrac.com or www.carwashsuperstore.com and order oil from them for pumps
Leland
02-27-2008 23:00:16
I maintain carwashes ,find a good 30w non dertergant oil
PaulW_NJ
02-26-2008 12:28:58
Never thought of looking there. Thanks!!
soundguy
02-26-2008 12:10:23
Hit a HD or lowes.. I've seen oil for them setting on the shelf. in lieu of that.. a air pump oil.. would probably work.. like 30wND.. etc.
soundguy
lucas boy
02-27-2008 04:10:53
 Re: Oil for Pressure Washer Pump Crancase in reply to soundguy, 02-26-2008 12:10:23
i use synthetic motor oil in my old pressure washer.
soundguy
02-27-2008 04:44:38
 Re: Oil for Pressure Washer Pump Crancase in reply to lucas boy, 02-27-2008 04:10:53
I've seen quite a few synthetic compressor oils out lately.
Only reason I wouldn't use a motor oil, is that motor oils are usually detergent, thus suspending particles for a filter to remove.. most compressors i've seen have no oil pump or filters.. thus having suspended particles floating around the bearings 100% of the time is less desireable, vs just letting them set in the bottom of the sump waiting for that oil change / flush... That's also why i mentioned ND 30w oil.. etc., in leiu of the proper compressor oil..
soundguy
