Tool Talk Discussion Forum
Electric Impact...
JoeK(WI)
02-26-2008 07:14:32
Anyone aware of a decent 3/8 drive electric impact wrench?Mostly work on small engine equipment,1/2" is definite overkill.Have 3/8 air wrenchs,just thought I might try a 3/8 electric or even cordless if such exists.
dave2
02-27-2008 04:17:58
 Re: Electric Impact... in reply to JoeK(WI), 02-26-2008 07:14:32
Link
plenty of stuff on amazon. I bought a set like this, but instead of the impact wrench and flashlight, I got a florescent light and impact driver. The impact driver may be the ticket for you. I used mine to drive 6 inch screws and some big lag bolts in and screw down the roof of a stall and paddock we built.
Good luck.
Dave
jose bagge
02-26-2008 16:33:36
I use a Black and Decker cordless drill with both a 1/4" and 3/8" bit for sockets quite regularly and it does a fine job for me . This one has a "torque limiting" adjuster at the chuck to keep it from trying to twist your wrist off once tight. set on wide open, it's great for disassembly- I find i reach for it more often than my air tools.
Mark - IN.
02-26-2008 15:56:08
Its a funny thing about cordless. If you had asked me about cordless 20 years ago, I'd have laughed at you, and may have. Now I drill through 14" brick walls with 18V Hilti like drilling through hot butter. Are lots of good out there like DeWalt.
soundguy
02-26-2008 12:08:16
I've seen cordless and corded impact wrenches at walmart...
'lug nut wrenches' can be usefull.. they are sometimes cheap but bulky and many have cig adapter or battery clips..
soundguy
Bryan in Iowa
02-26-2008 10:32:47
ingersol rand 3/8 14v cordless,,,best i have found , use it everyday
Tim B from MA
02-26-2008 08:40:25
I use a 1/4, or 3/8 or 1/2 socket adapter in a cordless drill to spin nuts fast. Still need a wrench to get them started off, or set on though.
flying belgian
02-26-2008 07:54:14
We use an 18v Dewalt to install wheels on trailers when they arrive from factory. Probably whiz on 200 nuts each time and that thing is just as strong on last nut as first. Same battery for entire job. Really a nice tool.
TimV
02-26-2008 07:29:55
Got a DeWalt 18V cordless impact last summer--best thing since sliced bread! Not a fan of DeWalt tools in particular, but got this at a garage sale for $50 barely used, so I couldn't pass it up. Has the quick-change hex drive on it, so I can use any standard hex drive bit plus 1/4, 3/8, 1/2 sockets with an adapter. It's the cat's meow for things like deck screws and lag bolts, plus it does wonders on nuts and bolts as well. Most mechanics I know have went to cordless impacts for all but the most demanding applications--much easier to maneuver than an air impact as you're not dragging a cord everywhere.
