Tool Talk Discussion Forum
electric motors
MF294-4
02-26-2008 05:50:56
What is service factor? Motor I'm looking at has a rating of 1.00 and others have 1.15. I know why some run 1750 rpm and some 3450, the 3450 ones are cheaper. Are they less efficent, less starting torque. We are talking about 5hp for a compressor. Grainger has a 5hp 3450 rpm GE for $105, the cheapest I have found.
Bus Driver
02-27-2008 04:20:08
 Re: electric motors in reply to MF294-4, 02-26-2008 05:50:56
Along with the post by markiz41, a higher service factor means that the motor will work satisfactorily with long conductor runs which cause voltage drop. This is especially often the case for farm use and deep well applications. In any event, low voltage at the motor results in higher amperage draw, greater heat and shortened life.
Philip Doolittle
02-26-2008 08:32:12
Electric motors with a Service factor ( SF ) of 1.0 operate at 65 degrees Celcius over the temperature where the motor is located. Motor of 1.15 SF operates at 50 degraas over amdiant air. The electrical insulation on the motor windings has a MAXIMUM temp rating of 65 degrees over ambiant temp. What all this means is a motor with 1.15 sf can run without burning up with a 15% overload. THIS IS THE RIGHT TYPE MOTOR FOR A AIR COMPRESSOR as it starts frequently and needs this 15% extra capacity to start more frequently than a motor with a 1.0 SF (which by the way should not be started more than 2 times per hour if connected to a load of its rated horsepower HP) Some mfgr's use a larger HP motor than the loan to avoid overheating a frequent starting motor, but this wastes a consierable amount of electric power when running. FYI some motors which start frequently under full load (a deep well pump motor) may have a sf AS HIGH AS 1.65... Need further info feel free to contact me. As a retired Elec Engr with 24 yrs experence protecting motors I would be happy to advise you what type/size protection you should have for your application. Would need NAMEPLATE DATA from motor.
John T
02-26-2008 10:46:48
 Re: electric motors in reply to Philip Doolittle, 02-26-2008 08:32:12
Great info, I knew it all had something to do with heat n duty cycles n loading lol it was 1970 when my first EE job was with Century Electric Motor Co but I done long forgot most of that motor stuff grrrrr r
John T also long retired EE
Gerald J.
02-26-2008 11:49:18
 Re: electric motors in reply to John T, 02-26-2008 10:46:48
Actually I think service factor comes from available wire sizes. Can't get them in steps smaller than a 1/4 of a gauge and going the next available size larger gives the winding a bit more current carrying capability (at the motor's rated temperature rise) than needed for the nameplate HP, so that added capability gets used in the service factor. Otherwise instead of 1/4, 1/2, 3/4... steps we'd find motors rated at 1/4, 9/32, 19/64, 5/16, ... steps. Cause really the 1.15 SF 1/4 hp motor is rated at 0.2875 hp.
Whatever, the greater the service factor the cooler the motor will run at the name plate shaft load or the more load it will supply without warming up too much.
Gerald J.
John T
02-26-2008 06:55:09
MF, it is related to duty cycle n depends on full or slight over load run time versus idle or less loaded run time as I recall (been yearsssss s since I was with Century Electric Motor Co ). If it can withstand x amount of overload for x amount of time without overheating I believe such represents an increased Service Factor (again, its been years so NO WARRANTY ON THAT)
The higher RPM motor has less poles (poles x RPM = 7200) meaning less copper n materials cheaper to build Id guess)
Even with the use of starting capacitors to increase starting torque and head pressure unloaders to reduce starting torque, a big flywheel on a compressor still takes considerable effort to start up.
John T
markiz41
02-26-2008 06:10:11
Take the FLA (full load amps) value on the nameplate and multiply it by the service factor. You'll get the max allowed amp draw on the motor. Anything over that can cause overheating. A 3450 rpm motor will have less starting torque, correct-o. If you have a 2-stage pump, the 1750 motor is better suited to move it.
Gerald J.
02-26-2008 10:52:27
 Re: electric motors in reply to markiz41, 02-26-2008 06:10:11
Actually the 3450 motor will have half the torque of the 1750 motor. But if the compressor is belted for the same speed (half the pulley size on the 3450 motor), the torque at the compressor will be the same if the motor has the same starting torque characteristic number.
The 3450 RPM motor will be smaller than the same hp in 1750 RPM. So it has less material and so is less expensive. Just gets inconvenient when the belt drive needs to run a compressor at 600 RPM where the 1:6 ratio makes the motor pulley on the small side and the 1:3 ratio for the 1750 RPM motor would be more realizable.
On the other hand, wanting to run a shaper or tabl saw at 5000 RPM its easier to belt the 3450 motor than the 1750 motor.
Gerald J. working electrical engineer and farmer
