Tool Talk Discussion Forum
Water line freeze up
NP123
02-24-2008 19:34:14
I have two buildings that are served by one well. The main building has the pressure tank in a heated basement, and the water line to the second building runs under a kitchen that has a crawl space and then runs underground approximately 30 feet to the secomd building, and enters under the basement floor of the second building. It can be well below zero and the water line does not freeze up, but when it gets warmer out (low 30s) the water line will freeze up between the buildings. There is a driveway between the two buildings which gets a fair amount of traffic. The tennant normally lets a faucet run with a slow trickle at these times, but he was out of town for the weekend and forgot to let it trickle. I was once given an explanation as to why this occures when the temperatures get above freezing. Do any of you fellows/gals have an explanation as to why this happens when it warms up? Now I need to drag a welder down the steps to thaw out the line. It usually has to be connected to the pipes for about 30 minutes at low current to thaw out the pipes.
NP123
02-25-2008 06:47:18
 Re: Water line freeze up in reply to NP123, 02-24-2008 19:34:14
Thanks for the replies. I thought the driveway has some effect on the freezing when it gets warmer. I purchased these rental units about 18 years ago and ran into this problem the first year of ownership. One of the tennants has a truck with a plow and he does too good of a job of snow removal, in that he gets it almost right down to the surface. The water line was put in over 40 years ago by the owners of the property and it looks like they did not go deep enough with the line where it leaves the heated basement. The tennant went out of town for the week-end and forgot to leave a faucet trickle. This is the first time it has froze up in about 5 years, as he is an extremely good tennant and really takes care of things. I live 12 miles away and need to take a welder over to thaw the pipes. At age 66, the welder seems to get heavier with each passing year. I wrote up a procedure for thawing the pipes and I am about to laminate a copy and just hang it on the pipes in the basement. As a hint to others that use a welder to thaw pipes, use a piece of emeroy cloth to clean up both areas where you attach the welder leads and it cuts the time needed to thaw in half.
36 coupe
02-25-2008 03:08:10
Water and sewer lines under a drive way are trouble.Frost gradually moves down ward in the soil.A layer of tar paper or wood over the pipe will stop the frost.Problem is both materials rot away.I have seen a sewer pipe freeze that was 6 feet under a driveway.Plumbing inspector told me that when thawing sewer lines by pumping water in to the line he could feel the ice blockage right where the wheel tracks were in the driveway.The only fix I can think of would be to dig up the line under the driveway and put some foam insulation over the pipe line.2x8 panels that are used to insulate foundations.I put one of thes panels over the septic line on my sons house because he planned a front porch.You can thaw water lines by pumping water into the frozen water line a thru a length of platic tubing.A minature submersible pump in a pail works fine. There are steamers that thaw pipe.One expert said you cant thaw plastic pipe but Ive done it often.An old Forney welding book mentions putting a length of #10 wire inside a plastic pipe so a welder could be used to thaw the pipe.Pipe thawing with a welder should be done at low current,under 75 amps..
MarkB_MI
02-25-2008 02:59:26
It simply takes a long time for the cold to soak through the ground. Like a brick house that stays cool all day long in the hot summer sun, yet the air conditioner kicks on at one in the morning.
T_Bone
02-25-2008 00:26:09
Hi NP,
As the surface heats this pulls moisture out of the ground and around your pipe causing rapid cooling by evaporating.
They use this same therory in the deserts to cool beer. They bury the beer under the sand then pour gasoline on the surface and light it on fire. This causes the ground moisture to raise rapidly surrounding the cans thus cooling the beer.
T_Bone
msb
02-24-2008 20:55:09
Aw, just pile straw filled manure about a foot deep on the line and let nature take its course. lol. It actually works.
NP123
02-24-2008 19:38:42
Sorry about the post. I put it on the wrong forum, but I will gladly take the answer to this question if anyone has the explaination.
2x4
02-24-2008 20:42:58
 Re: Water line freeze up in reply to NP123, 02-24-2008 19:38:42
Seen this many times. The problem is the driveway as you probably already know. Where there is grass you are alright. But the bare ground of the driveway loses heat, whereas the grass holds the heat, so the problem area is only the driveway. Short remedy - welder. Dig on either side of the driveway & clamp leads there for fast thaw, clamp on at exposed places for long time thawing. Long remedy- dig driveway pipeline out & fill with hay, or bury deeper. Hay will solve the problem for 5-10 years.
JMS/.MN
02-25-2008 08:06:32
 Re: Water line freeze up in reply to 2x4, 02-24-2008 20:42:58
Organic material will rot away. I boxed four inch thick sytrofoam around our septic line only where it goes under the driveway. 15 years and no problem.
