Tool Talk Discussion Forum
Gauges...
JoeK(WI)
02-23-2008 07:18:25
Pressure gauges specifically.Local industrial salvage often has various pressure gauges on sale,in singles,pairs,lots of several.
In short are all pressure gauges basically the same,other than capacities/markings?For instance could"air conditioner gauges"be used for shop airlines etc,if pressures are within range of gauges.Or a nice brass 8" "steam gauge" maxing at 300lbs used as a main air manifold gauge?
NOT looking to use with flammable gases or such,just shop air.
Andy C
02-24-2008 12:08:45
 Re: Gauges... in reply to JoeK(WI), 02-23-2008 07:18:25
Just a thought...Just dont put them on your oxygen tank regulator....if they had been used for oil could make a bad day
Andy
Most likely..John PA
02-23-2008 14:02:51
I use air conditioning gauges on all sorts of pressure lines, exception is water, though.
Never had a problem with propane, actelyene, air, even hydraulic press. testing. up to 500 pounds. John,PA
Dale B
02-23-2008 09:00:03
Generally you would be fine. The Bourdon tube that operates the needle is made of brass , and so long as your pressure source is compatible with it , it will be ok. I am using several steam guages in my air circuit in the shop, great big ones you can see across the room .
