Tool Talk Discussion Forum
Truck lug nut tool
jack12345
02-22-2008 21:04:13
I've been looking for a all in one lug nut tool that is 1 1/4" on one end and square on the other end for removing inner wheel.Any one have a supplier ? thanks.
JoeBob/IN
02-24-2008 18:30:26
 Re: Truck lug nut tool in reply to jack12345, 02-22-2008 21:04:13
Most if not all BUDD wheels are 1 1/2" and most of the sockets are setup with the square hole inside the 1 1/2" end. Large auction site will have them, harbor freight, local industrial tool store, good auto stores, local truck parts stores, etc.
dieselpaul
02-23-2008 10:46:26
sures it not 1 1/2 inch? i know there is 1 1/4 lug nuts, but on combination tool, its usually the 1 1/2---don't believe a 1 1/4 hex would have enough wall thickness & screw over a 1'' square stud. just a thought--paul
msb
02-23-2008 09:39:16
Try : www.gemplers.com
jose bagge
02-23-2008 05:01:38
Try Myers Tire Supply (myerstiresupply.com)
they have all of this stuff
tiresntracks
02-22-2008 22:37:54
If its 1 1/4" on one end, it might be hard to find. If its 1 1/2" on one end and square on the other, you can get them from Napa, Snap-On, Mac, and several others.
Armand Tatro
02-22-2008 21:14:25
Have you tried your local Snap-on dealer? Do you have a 3/4" drive socket set? Also Northern Tool & Equipment cat. Armand
504-2
02-22-2008 21:14:17
Check with your local tire shop, they will know who in your area stocks them. BTW remember if there is a L stamped in the end of the wheel stud it is LEFT hand thread.
